The wider bar will slow the steering down and it’s this principle property that helps to improve control going downhill; ostensibly, reducing the sensitivity to steering input at higher speeds means that you have more room for error but the wider bar also gives you greater leverage making carving around corners easier. The reverse is however true at slower speeds, such as when climbing, which requires very precise steering inputs in order to keep the line you want and maintain forward momentum. In theory then, a wider bar is going to make that a little harder to achieve so as with a slacker head angle, the front might tend to ‘wander’ a little and you might find it harder to control where the bike goes.
Please don’t take this as gospel however, I am only basing it on my own experience.
