Viewing 27 posts - 1 through 27 (of 27 total)
  • Do Spesh Purgatory 'Come up big' ?
  • jamiesilo
    purgatories look good for me and not that pricey.
    are they nice and voluminous?
    will be on Flow ex rims
    ta
    mikekay
    their a good size not massive, butcher comes a bit bigger. both good tires though
    kayak23
    Butcher on the front, purg on the back. Both nice and volu…volim….. Vollumni…. Big.
    coolhandluke
    Selling a couple of hardly see Purgatory here if interested £12 each. Or 2 for £20.
    Grid and control varieties, 27.5 BTW.
    devash
    They’re a nice size for a do-it-all tyre. Currently running 2.3 Purg on the back, 2.3 Butcher on the front here. I personally wouldn’t want anything bigger for general riding.
    tomaso
    They are skinny compared to most tyres of the same quoted width, certainly skinnier than a Butcher or a Slaughter. I also found the grid casing lacking in meat as they are a bit lighter than the other grid casing tyres and I got lots of pinch punctures…
    Want to buy one lightly used 27.5 x 2.3 Purgatory grid?
    ir_bandito
    Fairly. Had no problems with them on my Fortitude.
    Not the best guides as I didn’t include a ruler in the pic:
    2.3″ Purgatory on a 25mm superstar DS25 rim on the left
    3″ Dirt Wizard on a 50mm DB-X50 on the right
    jamiesilo
    thanks everyone
    i actually want as big as i can get, though not convinced a dirt wizard would fit in the frame. got 2.4 fat alberts at the mo but the new ones don’t look that convincing.
    i’ve about 10 or 12 mm either side so room for a little more but those dirt wizards look monstrous! thanks bandito. fancy crackin g out the tape measure/verniers?
    ever put one on a narrower rim?
    kneebiscuit
    Coolhandluke yhm re. Tyres
    jamiesilo
    and i’m on 26s me…
    twonks
    I’ve just put 2 on my bike as I got fed up with the leaky sidewalls on Conti Trail King 2.2.
    The 2.3 Purgatory isn’t quite as wide as the trail king but only a bit in it.
    Much much easier to seal tubeless and although not as grippy they are a good tyre for the money.
    sl80
    Tomaso, how much are you after for the grid?
    superfli
    My Purg grid 2.3 is wider than my Butcher grid. Only by a little, but it certainly isnt narrower.
    wilko1999
    superfli +1
    richardthird
    Couple more for comparison. Crests, 25psi tubeless
    Purg 2.3 56mm (under)
    Smorg 2.25 58mm (spot on)
    Chunky 2.4 62mm (spot on)
    jamiesilo
    So a purg 2.3 comes up smaller than trail king 2.2?
    Are conti 2.4s (trial/mountian kings) massive then?
    Are they any good these days? Old mountain kings (I think) got a lot o bad press
    What is nice and big without necessarily having too much of a DH tread and weight?
    And lastly, has anyone tried the new fat Albert’s?
    chakaping
    Don’t get the Purgs then, they are a bit skinny IMO.
    Schwalbe 2.35s are pretty meaty. On One Chunky Monkey also.
    superfli
    I’ll put a few tyres in a comparison tonight for you. I have Chunky Monkey, Smorgs, Butcher grid, Nevegal Pro, MM which I will photo against the Purg grid. All on rims (granted some are wider rims)
    IMO the purg is amongst the biggest of those.
    jamiesilo
    Thanks.
    Aye, I’ve got/had mostly schwalbe 2.35s. Nice and big yep, wouldn’t mind even bigger…
    boxelder
    Smaller than a 2.35 Hans Dampf
    ir_bandito
    I can’t measure the Spesh tyres now as they’re off, but for scale, the Dirt Wizard on a 50mm rim measures 68.5mm at the carcass, 74.something at the widest part.
    jamiesilo
    aye, that’s a bit too much for my frame, but only a bit.
    they look like a whole lot of tyre too, or maybe the prugatory next to it is just a bit puny?
    ir_bandito
    I never felt the purgatory was puny, its just the DW is a monster.
    qwerty
    Only the TKs, yes they are big, big in volume. Excellent tyres in Black Chilli compound and Protection (or Apex) sidewalls.
    jamiesilo
    Bigger than 2.35 schwalbes then?
    danjthomas
    Run a purgatory 2.35 on the back of my stumpy on arch ex rims.. No issues.
The topic ‘Do Spesh Purgatory 'Come up big' ?’ is closed to new replies.
