I had trouble getting an Advantage on my Flow a while back.
In the end I inflated using a tube and left a couple of hours.
I then rested the wheel on a bucket so as not to disturb the bead and deflated. Then I took the tyre off the rim on one side about 4 or 5 inches round the valve leaving rest of the tyre seated, cut the tube in half and slid out. Popped in the manfat, re-fit the tyre and up in went first time as it only had 4 or 5 inches of tyre to seat.
A waste of a tube and you’ve got to ask whether this tubeless game is a load of faff but cheaper to try than buying a rim strip.
