I get the feeling you mean “hi and low speed compression and high and low speed rebound”? Not “Hi and low speed compression, and rebound”?
Not that I know of. If you mean the latter then yeah you’ve got the answers you need above.
Are the new RS dual flow rebound cartrages internally adjustable? If so that might be the closest you will get. Well unless avalanche of somebody similar do a 4 way.
Lyrik lacks the hi-lo rebound but personally, I don’t miss it at all compared to my boxxers anyway, they feel downright odd if you set the hi and lo significantly different, I always end up with the rebound feel basically the same as the lyrik anyway
I’m not sure whether this is a peas-and-mattresses thing or a Northwind’s-senses-are-all-dead thing
But at least with it all being adjustable you can experiment, even if you eventually end up with a similar setting for hi/lo speed. The problem i have is i can never decide if the std factory setting for say low speed compression is decent or not!
Although i can see that sometimes, choice can indeed be the enemy of happiness 😉
You’d think that after 15+ years of suspension fork development someone would have offered a 4 way adjustable but they all seem more interested in creating yet another acronym for the marketing department. Maybe it’d be so lost on most of us that it’s not worth it.
There is probably quite a lot of truth in this. I am by my nature a fiddler and a faffer always looking for what is wrong and what I can improve. With all my forks and shocks I tend to fiddle at the start until I get a setting I am happy with, which is invariably a compromise, and then every so often I try to improve upon that setup and make it all worse again 🙄
I was never quite happy with either my Fox 36 RC2 Float or Marzocchi 55 RC3-Ti. Both had traits which I liked and disliked and no amount of fiddling with the adjusters helped without causing other issues. So I bought some Avalanche cartridges for them and have lived happily ever after… without feeling the need to fiddle with any of the settings… not one! They just feel so good in the stadard setting I have not touched them. Same with the CCDB I had; I liked it but I could never get it feeling quite how I wanted all the time, and yet the Avalanche tuned DHX-Air I am running now has required no such faffing and is awesome as stock.
I liked the CCDB and learned a lot about setting up suspension from it (and about how I want my forks to feel as well), but having all the adjustments in the world does not necessarily make the shock or fork feel any better IMHE.
FWIW – buying the Avalanche stuff is expensive and was a bit of a gamble instead of just buying new shiney stuff. The Avy carts allow you to change low rebound and compression, although you can adjust high if willing to take them apart and faff with shim stacks (the guides that Craig has written on how to do this and what changes to make to affect what seem very detailed, although as I wrote above I have not felt the need to change anything).
I’ve written about my forks and shocks on here a few times… I’m a fan of the Avalanche stuff as its the best suspension I have used
