Viewing 8 posts - 1 through 8 (of 8 total)
  • DIYTrackWorld – electrical trunking
  • cinnamon_girl
    What do I use to cut it please?
    Thanks. 🙂
    JonEdwards
    Plastic or metal?
    Junior Hacksaw works OK on small plastic stuff, or you can buy dedicated shears. Mitre saw with a fine blade if you’re into complete overkill.
    Metal – I’ve used hacksaws, nibblers, battery powered bandsaws (GREAT toy), anglegrinders and chopsaws before, depending on location of work and availability of the above.
    wwaswas
    I use a hacksaw on plastic. Bit of emery cloth if you want to tidy the end up afterwards.
    cinnamon_girl
    Thanks for replying. It’s plastic and I might just have a junior hacksaw in my tool box!
    cinnamon_girl
    Emery cloth?
    northernmatt
    Sandpaper
    wwaswas
    wet and dry, sandpaper, even a file. Just somethign to take the ‘rough edge’ off any of the ends that may be visible.
    Wire wool works quite well on kitchen waste pipe which is the same type of plastic.
    cinnamon_girl
    Ah OK, thanks!
The topic ‘DIYTrackWorld – electrical trunking’ is closed to new replies.
