The finish is not that good as i just wanted to ride it and not spend 3 days sanding so people can go “ooh shiny”.
Good bits: Spending hours on bike checker seem to have worked, it pedals really well with not much bob when seated. No creaks or cracks and it all fits me perfectly.
Bad bits: Finish is a bit “plasterers radio” as chuck a quick coat of resin on to cover the bare carbon. Will sand it smooth on day.
The swing arm needs looking at as it flexes badly, reminds me of a white e5 if anyone had one. If you stamp on the pedals you can see the wheel twist (a plan is hatched that wont be pretty but this swing is officially the test mule for the next one).
Oh the cap on the mech hanger fell of on the first ride. Still managed a few rides as it almost a press fit in as it is.
So not finished, but at least i can twiddle about now
So the bike was then put back together with all the fasteners thread locked.
I decided to be decedent and bought a front brake adapter rendering the 5min fix redundant.
The bike all back together, before i ruin it with mud guards.
So a test ride was done yesterday around Sherwood pines. A few runs down the “down hill” runs and no creaks or crack and some climbing where possible.
Over all am pleased the bike holds up well i just need to get fit enough to pedal it and used to riding a full suss after nearly 2 years of rigid. Had some nice comments from a few people i met on the down hill run which was nice.
In three hours of mincing these are the only bolts to have moved.
I think the biggest compliment about the bike is it takes people awhile to realise it’s home made.
Inspirational stuff! It’s got thinking about if I could do something similar.
Although I don’t have a 3D printer. Maybe build the front triangle out of stock tubes… 😉
Geometry is spot on for me, looks a bit strange when un-sagged but managed most of the climbs on a peak route (fitness allowing).
A few problems flex on the swing arm to front triangle is bad when climbing rocky stuff, not unnerving just flexy. This has led to a bit of chain ring to chain stay interference. I think some of it is due to the design of the swing arm and some to the polymer bearings which have to be a super tight fit and still give some radial give.
So a plan for mk2 is being hatched to solve some of the issues.
This was the original idea, i just got carried away working out ways to make the rear end, (which is the hard bit).
For my first go, I’ll probably re-use a rear swing arm from something or other. I have the front triangle modelled in CAD, I would have to place the pivot points to replicate (as best I can using linkage X3) the bike the swing arm came from.
The bike looks good, glad you’re getting hours in saddle testing. I’m sure you’ll sort out the rear end flex.
Not if I can post this here, butinstagram
The pivot bearings seem to be more substantial than yours, maybe you should start there!
Where has the time gone?
A plan was hatched for a mk2 swingarm using some inspiration (stealing the ideas) from specalized to fit bearing in the links, that way I wouldn’t need to re make the frame.
Printed out with very little infill and is over 100g lighter than the old one.
And then work/ life actually riding a bike got in the way again. last week i had a crazy stressful week at work so to wind down had a weekend on CAD, which turned into looking at the frame design and seeing if it could be made lighter. I got carried away.
Completed abandoned any internal support and my four layer thick test sample is quite stiff so in a tube should be good enough. Am after 1kg off the frame. This might be a slow burner though.
Do you have a background in engineering?
I was an apprentice tool maker and CNC machinist. Now teach engineering at a college, I use the lower links for a lesson on CAD use for a virtual stress test which always goes well. Have basically taught myself Solidworks though over the years.
[Rant] If I was a purveyor of certain bike products I could plaster this all over Facebook saying how awesome I was…[/Rant]
So here we go again!
Decided to put the bike back together and just ride the thing, so after building it up, changing the air shaft in the forks and packing the spare frame away i found this.
Bugger- A crack from the chain stay de laminating across the pivot, well I’ll have to do the other swing arm now.
So a weekend CADing between Dad duties and got the bike assembled to check clearances (already had most of the separate parts modelled).
This let me then sort the jig out and work out what needed to be changed, to make life easy on myself i seem to have widened the rear pivot and narrowed where it meets the rocker so some of the jig parts at the minute are useless.
Along with changing some dimensions I’m going a different route with the bearings. It’s all been designed with asymmetric bottom bracket area (not current set up) so once again printed off some parts to check.
Nope needs more cowbell clearance
That’s better, just a dimension change and 20min print.
I’ve also managed to make some new jig parts and tools I’ll get some pics and upload later on.
So impressed, my mrs has a degree in Engineering Design and Technology and CAD was what she loved, she even did a little bit of CAD work on designing a Unicycle so she’s blown away by it too.
Thankyou all for the kind comments, glad someone finds my rambling interesting.
Loving this… I see you’ve deviated from the One True Glue Stick, purple elmers glue, do you find it makes a difference?
I used to use a glass sheet/ mirror but bought a new aluminium backed heat bed. I find the blue tape just works better. But i’ve spent along time leveling the bed and setting the extruder height to get the first layer right.
Yeah, I spent ages mucking about til I realised all I really needed was the right temperature on the bed and the height and settings just right. I mostly use purple glue straight on the bed but every so often, some bloody print won’t come off the bed and needs soaked off 😆
As mentioned I’ve widened the rear pivot by 10mm so made a spacer.
Here’s the mandrel as normal.
And here it is with the spacer.
Now epoxy is sticky stuff so to expect the spacer to come out easily is foolish, what you need is a tool to push/ pull the spacer out without twisting out of round or damaging the spacer. so 10min on a lathe you end up with..
It doesn’t touch any of the mating surfaces and is threaded so in theory I can pull it out using an existing washer, the main diameter is 0.1mm small so should stay concentric’ish.
Also rattled up a spacer for an existing jig part and a new part to hold the rocker connectors in the correct place.
That’ll do for today, looks a lot but didn’t take that long to do.
The new swingarm was glued together ready for the first layer of carbon just to hold everything in place. The a mishap i kind of left it near a heater turned up to high and it warped.
So this stupidly gave me time to adjust the design slightly, which obviously took way too long involving the front triangle, we’ll get to that later.
