Hi Chaps,
I’m making a ceiling for the van, to tidy up the insulation and eventually put some downlighter LEDs in.
What material would you use for the ceiling? I was thinking hardboard covered in headlining, with batterns on the rear for stability.
I did think MDF would be better, as it has less flex – but I’m thinking it’ll just turn into mush if there is any condensation?
The roof has ribs across, which the board will be directly screwed into – but there needs to be holes left for the lights. At the moment I’ve cut smaller pieces to make a template and intend to cut larger pieces to fit.
Any help appreciated 🙂
Ricks
