My neighbour, a retired plumber but now rather frail, has two 30 year-old solar water panels on the south side of his house. The engineering is quite good and robust – he bought the panels then wrote to Honeywell explaining the project and they sent him a package of temperature sensors and a controller. It’s all piped up in 15 and 22mm and there’s a 240v circulator, unlike my modern setup with 12v electics and 10mm piping feeding a manifold with evacuated tubes.
Now the covering on one of the panels has torn open. Closer investigation up a ladder yesterday revealed that the panel is nothing more than a 4′ x 6′ aluminium frame, with insulation in the back, flat aluminium sheet collectors with a very narrow pipe running down the middle and then a sheet of heavy poly stretched drum-tight over the frame and finished off with an outer frame that appears to be glued on with exterior mastic.
So we plan to strip off the outer frames, remove the old poly, spray the collectors matt black with a rattle can then replace with fresh poly and mastic the frame back on. I then need to find a way of shrinking the poly sheet, in the same way as you do with that thin film you can use as temporary secondary glazing where you use a hair dryer. I’m aware that the forces of shrinkage could tear the sheet out of its frame so might need to leave it slack for a week or two for the mastic to cure. I’m thinking that a 3 kw electric fan might deliver enough heat over a broad area to do the job but I wonder if it will be hot enough; I know that in factories where cans and bottles are shrunk into cartons a gas flame is wanded briefly over the plastic to shrink it.
Any suggestions?
And before you ask – no, my neighbour has declined my offer to replace the two panels with one efficient 20-tube array like I’ve got, which would be a straight swop.
