molgrips – Member
Some GPS units use wheel sensors too.
You’d know if you had one as you’d have had to fit the sensor to the bike.
That said, wheel sensors are more accurate on rolling distance, though need accurate wheel size calibration on the day. Typically they’ll be quite different to GPS distance. I found distance and speed with a sensor was generally lower than GPS, so was coming out worse than friends. Stopped using the sensor now, though mostly because it kept getting knocked out of position.
superfli – Member
Check GPS settings for Glonas or just GPS. Also ensure that they are both set to 1s recording.
Neither 500 or 810 have GLONASS.
Reality is it’s complicated and many variables can cause difference. Even with seemingly identical models, it can be down to timing when acquiring satellites so it gets different fixes to the other, or just being a few metres apart or off course, one happens to lose satellite sight because of tree cover but bike next to it is getting clearer view, etc.
How long you wait for a GPS fix or after getting a fix can be important too. GLONASS for example is mainly of benefit to get a quicker fix by adding a second group of satellites, and likewise phones use A-GPS by phoning home via mobile data to get satellite positions quicker. These speed up getting a fix, but it’s an adequate fix, not necessarily all the satellites possible. Enough to track, but maybe not perfect. Once moving it may or may not pick up the rest.
https://www.dcrainmaker.com/2011/06/2011-sport-device-gps-accuracy-in-depth.html
https://www.dcrainmaker.com/2011/06/2011-sport-device-gps-accuracy-in-depth_09.html
