Did this on my own in December. About a 2 hour job. Make sure you have an electric screwdriver. The only thing I struggled with was removing the hydraulic lifts. I called Asgard who were very helpful. Basically you have to het a screwdriver under the silver clip and lever it off. Do this under a cloth or something as it is likely to ping off and you’ll spend a while trying to find it. In my case this took quite a lot of persuading, clipping it back on the other end was a bugger too. Thinking about the wooden base was a little awkward to get out on my own but manage it with a crowbar.
Would be made a lot easier with another set of hands
I had a big a3 envelope for the parts, and wrote out the dismantling order on it as I went. Drawing around the appropriate screws so I knew which fasteners were for which step
Built up fine at the new house.
Edit – I didn’t reverse the installation instructions, it’s pretty obvious.
