Viewing 5 posts - 1 through 5 (of 5 total)
  • Disk brake question
  • juan
    I know I can fit a IS disk to a centerlock hub buy using the DT gizmo.
    Can I fit a Centerlock disk to and IS hub using something similar?
    Mister-P
    Not that I am aware of as using an adaptor would move the disc too far away from the hub.
    juan
    boo 🙁 thanks.
    Lot of faf it is then …
    crazy-legs
    1) It's disc
    2) You can get an adaptor that allows a 6-bolt rotor to fit onto a centrelock hub. You can't do it the other way round (centrelock rotor onto 6-bolt hub)
    Olly
    i would go with rotor myself :p
The topic ‘Disk brake question’ is closed to new replies.
