Ok, help needed / possible stupid question time!
I’ve fitted the deore brakes to my son’s bike and successful shortened the hoses. First time if ever done that job and was pleased with the result.
However the rear brake went on fine, although using the shimano supplied shorter bolts. Not the original Avid ones.
The issue is the front. The rotor is a 180 g2 cleansweep. The caliper will not line up. The pads sitting above the top of the rotor by a couple of mm. The supplied Shimano bolts are too short. The stock Avid ones had 2 spacers either side of the caliper. I’ve tried a few different combinations but can’t get it right.
Anyone successfully sorted this?
Thanks in advance.
