Viewing 5 posts - 1 through 5 (of 5 total)
  • direct drive turbo trainer
  • creakingdoor
    I’m looking to purchase a direct-drive turbo trainer, but my bike has an 8 speed cassette. All the turbos I’ve looked at support 9 up to 11 speed cassettes; are they fundamentally different? As I don’t have a 9 speed I’ve got nothing to compare with.
    Is there any particular reason why an 8 speed cassette won’t fit?
    singlesman
    Just bought a Elite roteo direct drive trainer which works perfectly with 8 speed despite saying it’s only compatible with 9/10/11.
    Just needed a extra spacer behind the cassette so it tightens up on the free- hub properly.
    Hope this helps, Paul.
    creakingdoor
    Thanks Paul. I wonder if most of the others also take an 8 speed with the same addition of the spacer.
    simondbarnes
    Any that’ll take 9/10/11 will take 8. You’ll need the same spacer that’d be needed for 9spd. You could even fit a 7spd if you wanted.
    creakingdoor
    Thanks Simon, much appreciated.
The topic ‘direct drive turbo trainer’ is closed to new replies.
