Some of my more memorable dismounts
Best:
Going a bit quicker than usual, find myself heading toward a shallow ditch. Figure its better to ride voluntarily into the ditch than just slide into it. Haven’t looked far enough down the trail to spot the ditch terminates in a big tree!
Somehow in the split second before I hit the tree I step over the top tube, sit down on the grass bank beside the ditch and let the bike carry on. The bike’s front wheel finds a perfect gap between a root and the trunk and just sits upright as if its been gently placed there.
Fast:
In a race, so going for it, narrow downhill single track across peaty ground. Spot a patch of big muddy ruts ahead, figure with all the speed I have I just need to lighten the front wheel to skim across the mud. Wrong! Front wheel digs in and I go flying, proper superman, I must have went 15 feet. Hit the ground with a fairly hefty “ooof” but not too bad as the ground is still pretty soft. Bike clatters me square in the back a split second after I think I’ve got away with it!
Slow:
Get to a tricky step on a traverse across a steep hill, try to dab where there is nothing but fresh air and then bounce all the way down the hill!
