I have a pompino and run it SS and fixed occasionally, on the road. In order to try and get a bit more off-roady I want to drop the gear ratio down a little.
If I fix 2 sprockets onto the hub, I’m happy to manually drop the chain off and swap it over when I want to change – wont happen very often, and should only take a couple of mins anyway.
Does anyone know what size change in sprocket teeth number the track end can accommodate whilst keeping the chain the same length?
I was thinking along the lines of 42t front and a 16 / 19t rear which would give me about 70 and 60 gear inches respectively.
What does this equate to in terms of the (effective) chainstay length? Is there a (easy!) way of calculating it?
