Viewing 8 posts - 1 through 8 (of 8 total)
  • Di2 probs
  • jkomo
    Brand new bike, (my mates). Rear mech stopped working on first ride.
    Any one else had probs? Can’t get it back to shop till next week.
    Battery fine, front mech fine.
    Rorschach
    Have you tried turning it off,then turning it on again? 😉
    Connections,usually at the shifter.You need the little tool though or you WILL pull the wire out.
    jkomo
    I thought it needed a reboot but can’t find any info on tinternet.
    jota180
    Another 50p in the meter?
    Rorschach
    ctrl,alt,delete?
    Rockabilly
    Have you read the instructions?
    it may be in “rear derailleur setupmode” where the mech moves teeny amounts when you press the shifter, to do the same as winding your barrel adjuster on a cable mech.
    hold the button on the battery indicator for 3 seconds or so, and try again.
    Maybe?
    tang
    Has been known, some pro conti mates had two go on a long wet early season race in Belgium.
    jkomo
    Thanks, luckily bought from a shop with people in it. Back it goes…
The topic ‘Di2 probs’ is closed to new replies.
