So TBC, how did you get on with it?
Unless bigger wheels must use shorter cranks, the likelihood of a pedal strike won’t change one bit. A 14″ bb height is a 14″ bb height regardless of running clown wheels or not
Weeelll not quite. The tyres are effectively longer so take longer to roll onto/over/off an obstacle at the front, and start doing so earlier at the back. Imagine rolling off a step… When the “bottom” of the wheel is 6 inches off the step, the front end will be lower than if you repeat that situation with a 650B or 29er, so clearance will be less.
It’s a little like shortening the wheelbase, from that point of view- pedal/chainring clearance isn’t just about height.
