Right, well there’s a few lies floating around about this process so lets clear them out right now.
‘The worst is over’ whilst technically true (only because the root canal treatment is so horrendous), implies that fitting the crown is not bad at all. This is not true.
First off, he’d left a temporary filling in so he drilled that out. Then he proceeded to prepare the root for the ‘post’. This involved quite a bit of drilling, try and jam the post in, bit more drilling. This hurt… a lot. No need for a local though, it’ll be fine. Finally he’d excavated enough tooth to satisfy him and was ready to glue it in. Trouble was, my gums had grown over the hole a bit.
Does the dentist now…
a) Gently tease the gums back with a wooden spatula.
b) Provide a local anaesthetic and gently cut the gum away carefully.
c) Hack away willy nilly at the gum without any pain relief whilst smiling happily as blood sprays across his face. After all, it’s not his gum is it?
Answers on a Lidocaine soaked swab.
Right, so the scene is set. A huge great lump of metal pleasantly referred to as ‘a post’ has been lodged in my gum using copious amounts of superglue. My mouth is swimming in blood and salvia which the orange dental nurse is currently kindly trying to remove by jamming the suction tube half way down my osephegus and the dentist is peering closely at what is either a large tictac or a small suppository.
Can’t get any worse can it?
Now apparently the impressions that the dentist took of my teeth last time I came will allow the dental lab to create a finely tuned crown that will slot perfectly into place, and obviously the dentist has already ensured the post will fit the tooth, hasn’t he? How naive am I?
He begins drilling away apparently at random at the crown, occasionally having a quick shimmy on the post throwing shards of molten titanium into the melting pot of blood, bile, sweat and saliva gradually building up in my mouth while the assistant simultaneously texts her friends and sucks my throat tissues out.
Eventually he’s ready to glue the crown in place. The assistant, job done, leaves us to it so she can stick another half inch of eyeliner on and the dentist puts his crown fitting boots on. This thing needs to be pressed on hard and legs are stronger than arms.
When I wake up the crown is in and the dentist is standing there admiring his work. He presents me with a mirror to examine the masterpiece for myself. Gulping gently I gingerly hold the mirror up and look at what looks like the result of a proper fight with knives and bats and chains. It’s hard to tell how good it is because it’s covered in blood, brain tissue and burnt titanium but it’s certainly in the right place, looks like it might be the right colour and when I bite, it touches at the same time as all the other teeth.
‘Thanks’, I say, ‘is it supposed to be giving me searing agony constantly?’
‘we just scratched your gum a bit, that’ll go soon’, he tells me as he pushes me out of the door.
I try to pay but because my mouth has swelled up on one side and because the receptionist is not English, or indeed, has not been taught how to say anything in English, I leave only a few grams of flesh lighter.
