I’m getting a bit annoyed with this one now. I keep thinking I’ve cracked it and then it’s back the next morning. Small jumps, just the sort of thing you might find on a energetic crosstown commute, kerb hucks and the like. It seems worse if I’m in a fairly low gear. The chain tends to jump off onto the small ring and not want to come back without shifting to near the top of the cassette. I’m becoming convinced it’s chain tension, and basically rooted in road mechs being lighter sprung than mountain.
Bike is full 5700 except CX70 crank (essentially Ultegra 36/46). Chain is two weeks old, cassette and rings show no significant wear, shifting is crisp and clean, cable tension good therefore, chain is properly sized, front mech is as low as I can sensibly get it although it’s 5700 item intended to clear a compact not 46 but I don’t think this is the issue as its a common combo.
I almost never use the low ring unless I’m riding in the Peaks or doing big proper road with real climbs. I’m seriously considering investigating a Wolf front ring and one of their rear adaptors to run a Shadow+ MTB derailleur with road levers but that seems a techy solution for something I’m sure must be simpler.
Anyone want to tell me what I’m doing wrong ?
