• This topic has 44 replies, 21 voices, and was last updated 6 years ago by poah.
Viewing 40 posts - 1 through 40 (of 45 total)
  • DB Coil IL ([inline]
  • RicB
    HWDTY?
    Looks really interesting:
    Coil performance and reliability/minimal faffage, with a climb switch. ime one of the major advantages of coil shocks is the grip available on technical climbs, providing you don’t just mash the pedals in granny gear!
    And comes in a range of sizes to suit trail bikes (190×50 in particular)
    I’ve always thought lightweight coil is better than air for forks, so it’s cool to see shock manufacturers taking note too. Yes there’ll be a weight penalty but only a few hundred grams.
    My only thought is which suspension designs/leverage curves a coil shock will suit. I imagine most frames now are designed with a regressive leverage curve to account for the ramp-up of air shocks. So a linear coil spring might mean lots of harsh bottom outs.
    I’ve been toying with the idea of a Transition Scout for my new bike and Transition just replied to say the Coil IL will work really well on the Scout because of the slight progressive leverage curve 😀
    Tom_W1987
    Yeah, I quite like the idea to be honest. It comes in at about the same weight as a CCDB A – no need for the piggback for most UK riding – but the midstroke support, sensitivity and reliability would be a boon.
    Nobeerinthefridge
    Doesn’t come in size I need – 222×66
    Boooo!
    johnw1984
    I’ve been eyeing this up for the Aeris. Still wanting to try a coil on it and this looks like it would be perfect!
    strawdog
    any idea on prices ?
    russyh
    http://www.canecreek.com/store/suspension/double-barrel/dbcoil-il
    $550 plus your spring ($130 if going for the lighter valt) so $680. Who knows how that price will work out over here.
    kiksy
    Yeah potentiality this looks really interesting! Need to wait to hear some reviews on performance/reliability though.
    RicB
    Cane Creek reliability has been pretty good. The inline was’t perfect but most of the problems seemed to occur on Spesh frames, where the shock is directly connected to the swingarm so any frame flex caused major side-loading to the shock.
    $680USD is currently £513. So I suspect we’ll be paying £680!
    Hopefully it’ll come down a bit; charging more than a Float X2 isn’t going to do much for CC sales. £500 inc spring would be a sensible starting place
    Northwind
    I’ll never understand why it took so long to get coil shocks with climb switches tbh, it’s a proper gamechanger. As you say though there’ll be bikes this just doesn’t suit well, I can see it going a bit wrong in some cases.
    Tom_W1987
    Depends, I don’t see why people have such an issue with IFP coil shocks but are then perfectly happy to run an air shock. Sure IFP shocks aren’t as sensitive as bladder based coils, but you can stick a boost valve on them or increase the IFP pressure and get more bottom out resistance can’t you.
    That’s the reason why Pivot will tell you to go with an ElevenSix if you want a coil shock for one of their bikes, because PUSH built a shock that could be tuned around the wonky regressive leverage ratio.
    zerocool
    Anyone know if the Valt Spring can be used a regular CCDB? Or how they compare weight wise to a Ti Spring or SAR?
    Tom KP
    RicB
    Yes I’m expecting a few initial review along the lines of ‘bought this for my completely unsuited full sus coz it looked awsumz, no idea what the twiddly dials do, slower on Strava – it’s cr$p’ 😀
    Rik
    Not on the inline it hasn’t, I went through 3 in 12months (not on a Specialized) before Cane Creek offered an free upgrade to the AirCS. TF tuned were great through the process but they said that it had happened to a lot of other people too.
    It’s the problem about fitting so many complex parts in such a small package, everything is a downsized version of the airCS
    poah
    got one for my suppressor although I weighed myself on dodgy scales so over estimated my spring lb meaning I’m only getting 25% sag.
    chiefgrooveguru
    Except no Pivot bikes from the last few years have a regressive leverage ratio – they’re DW designs and have his usual progressive-linear kinematics.
    Inline Coil looks cool!
    jamj1974
    If it performs as well as it looks – it should be excellent! Love the look of coil shocks.
    RicB
    poah- how do you find it compared with the standard air shock?
    I spotted a specific aftermarket linkage for Santa Cruz VPP bikes to support the use of coil shocks. Now can’t find the link! Think it might have been part of the ElevenSix package.
    cyclelife
    Got one on my Nomad it’s A Push link.
    Thinking of this CC IL for my new Mega.
    Northwind
    Looking good! Not sure but I might have a 350 spring to fit that if you need one (if it was me I’d be getting some lightweight hotness though…)
    poah
    RicB – Member
    can’t really give you much as the spring rate is currently too high due to a inaccurate scale 🙁 it is however vasty more sensitive and less soggy than the monarch was on the suppressor. Its not that the monarch isn’t a good shock I just don’t think it was tuned right for the suppressors suspension.
    I’ve ordered a nukeprood SLS spring from CRC so will be able to let you know by the weekend.
    RicB
    £430 plus Spring is a bit steep though, it’s effectively a £360 dbinline without the aircan.
    poah
    The inline is cheaper as its been out a while but you’ll notice the dhx2 is more expensive than the X2. I do agree I was disappointed at the price difference but he exchange rate has got worse recently
    The db coil won’t fit my bike nor will the X2/DHX2 or x-fusion vector so his was the only option
    RicB
    Economies of scale too, I suspect :-/
    bennn
    Whyyyy did I have to see this!?
    Quite fancy one for my Rocket now, not that there’s anything wrong with the CCDBA on it..
    poah
    The coil has better inital sensitivity, its really quite a lot better than the monarch. The IL coil also has a bladder rather than an IFP so there is no stiction from that either. The inline also has more oil than a standard non-piggyback shock too. so for the average joe, they are not going to miss the effects of the extra oil on a piggyback air shock.
    http://wp.me/p4HYH0-28
    poah
    RicB – Member
    had a run today with the lighter spring, its bloody amazing compared to the monarch on the suppressor. weighs 655g with the nukeproof SLS spring. adjusted the rebound a bit from the settings TFtuned set up for me.
    pitchpro2011
    People need to be careful about chucking any shock on their bike. A lot of bikes are designed for an air shock and the linkages work accordingly, mine (ibis HD3) for instance with the dw link cannot be improved with a coil shock. Elevensix tried and failed to produce a tune for the HD3 that would improve performance. Before you point out the racer that runs an xfusion coil on his… he does so because of a bad back. I’d love to run a coil but wouldn’t get any benefit.
    tmb467
    Blatant sales pitch – I’ve got a 216 x 63 Xfusion Vector HLR coil (with 400lb steel spring) in the classifieds now
    benpinnick
    You’re looking at around 420 RRP with a coil and hardware FWIW. If you’re thinking of putting one on an aeris it will work fine. The leverage is progressive and will offer enough support to stop you blowing through the travel, although I would recommend if you’re split in terms of spring weights go heavier, not lighter.
    poah
    £430 incl hardware from tftuned but no Spring
    RicB
    £430 plus spring is the price I’ve seen. CRC might end up doing it a bit cheaper but that won’t include hardware.
    pitchpro2011 – Member
    Yep – I mentioned this earlier. It’s almost like we need a suspension kinematics expert to list the types of suspension where coil is best suited – calling chiefgrooveguru and Rik Draper….
    poah
    It’s not just the bike but the trails you ride.
    A coil will instantly improve small bump sensitivity on any bike
    parkstar
    but on a bike with a flat or regressive rate you can find it will just wallop throught the end of the travel and negate the small bump advantage by needing a much firmer spring
    poah
    my leverage rate while isn’t linear, hardly changes. Don’t think any bikes these days have a purely regressive rate.
    The 400lb Spring have me 25% sag and was better than the monarch at 30/35%
    RicB
    Exactly – it suits progressive rate suspension, otherwise you’d have to run so much HSC it’ll feel awful.
    parkstar
    yup, i also have a suppressor. from stock it had full allocation of bands in the monarch (not sure if this is the norm) and im contemplating a coil shock at the moment. the fact as standard the bike isnt HUGELY progressive worries me a little
    bennn
    I’ve been doing some reading up about the Rocket’s suspension design it has a rising leverage rate of 20%, so it sounds like it should work well with a coil.
    I’m going to spend some time fiddling with the air shock before committing to one though I reckon.
    poah
    RicB – Member
    it runs from 2.5 to 2.3 hardly any progession. If I ran my monarch at the same sag and no bands it would bottom out. The coil is much better because its better damped than the monarch even though its a linear spring. I’m only running 1 turn of HSC out of 4.5.
    chiefgrooveguru
    Most air shocks get softer in the early part of the midstroke, so a coil running the same sag will have more support there. The lack of seal stiction and friction in the coil will also mean you’ll get more sensitivity with equal sag. Rocket would be great with a coil!
    RicB
    Further support for a coil shock on a bike with a flat/neutral leverage curve comes from the fact Orange used to offer the Five with a coil option.
    I emailed Orange a few weeks ago actually; they confirmed the new 2017 Five has a slightly more progressive leverage curve (to mimic the feel of the Four but with more travel) so suits the coil inline really well.
The topic ‘DB Coil IL ([inline]’ is closed to new replies.
