The bars are a bit wider than the previous pair
Can you put the previous pair on, see how that goes? Bars should be basically the width of your shoulder blades.
It’s also easy to fall into the trap of having high-ish bars and a short-ish reach in order to get comfort, when in fact it can make things worse because you (counter intuitively) end up putting a lot of pressure on your hands.
It’s a trap I fell into, using a 100mm, flipped-up stem and it was never quite right. On a whim I stuck a 110mm on, flipped down, and dropped 10mm on the steerer tube (the latter because of a steerer cutting measurement oversight 😳 ). It’s much more comfortable, and I ain’t no skinny flexy racing snake.
