Sorry for the roadie question. Wondering if anyone has had issues with Giant P-SL0 wheels and tubeless? I’ve had no troubles with tire seating on front wheel, but no end of trouble on rear wheel. Giant very kindly replaced the wheel once already under warranty (without fuss and very quickly I should add), but now having the same issue again – tires simply won’t seal. Have tried replacing/adding tape, different tires (all Hutchison brand, mind you), no luck. Done all the usual – pump up with tube, unseat one side only, etc etc etc.
Just wanting to know if anyone else has had this issue, or (more likely) just bad luck on my part…
