I had numerous damp ‘experts’ (read: salesmen) try to tell me that my 1890 terrace had rising damp, and that this implied armageddon.
They all wanted to do ~£10k worth of removing render and plaster, injecting liquid DPC and replastering with their own special magic plaster.
I sorted the actual problem, which that the external render was in contact with the soil, put a bell cast bead on the bottom of the render, and a French drain to take the water away. Inside I improved ventilation. Sorted.
I’d recommend you get water away from the base of your walls (so the land drains seem like a good plan) and improve ventilation so that any moisture within the wall can escape harmlessly.
Your house has stood fine since 1750 without any need of electric probes in the wall. I suspect it will be fine without them for many years to come.
Dave
