Just bought and fitted a Magic Mary to the front and Hand Dampf 2.3 to the rear of my bike (Ibis Mojo SLR), and think the rear is too wide.
Looks to be 2 to 3 mm clearance each side and I thought it would be ok but, a ride out today had me sure I heard it rub very slightly coming off a burmed corner. (The frame is ok and all the bearings have just been replaced so the rear triangle is square and solid)
Bit of a nuasance as I’ve also filled it with stans liquid, so returning it to CRC is most likely a no-no.
If I keep it in the Schwalbe family, what works well on the back (26″) with Mary up front, and is slightly narrower than the HD?
Went with these pair due to the reviews they get and I just fancied a change from worn out Purgatorys.
I’m a big boy at 250lb and ride anything apart from DH and jumps.
