Hey, hoping some of you might be able to help me. I’ve got a rear wheel with a shimano m475 hub. However, I somehow managed to mangle the dust cover, on what I assume to be the left hand cone, aswell as half of the ridge that the dust cover sits in. Heres a photo;
Basically I just want to know if this is fixable? Am I right in thinking that the mangled part is just a dust cover, and does it count as part of the cone? I’ve looked at the manual for this particular hub but this part doesn’t seem to be in the manual. If sits possible, where can I buy a new one from??
LOL,yes it’s fixable,no you can’t buy a spare part for it.
if you can find an old hub,you can get a cover out of it,but,they’re not easy to change,as they’re not supposed to be re-used.
good old Sh1tmano !
if you’re any where near Birmingham,I could fix it for you.
cynic,where ?
last time I asked at a Shimano stockist lbs,they said that cones and seals are listed,but they’d never been able to order them,as they were always ‘out of stock’,’discontinued’ or ‘unobtainable.
Yes it is fixable, but probably best to let someone with cone spanners and proper tools do it as it looks like your hammer and chisel method has failed miserably 😀
Have an old dead one of those with undamaged parts which you can have if you are near the Burton on Trent/Derby area
Done that, doesn’t appear to be a part that matches the hub number. There is a part called the m450 left hand cone & seal. But I don’t know whether a. it will fit the m475 hub, and b. if it includes the dust cover!
Afraid they’re considered part of the hub-shell(google shimano techdocs, searcg m475), and not available seperately. The good news is that your favourite Uncle Coatesy has one in his spares box from the M525 conversion mentioned above, e-mail me your adress and i’ll put it in the post for you.Old one’s best removed using a snug fitting socket and extension inside it, and gently wiggling it out(not hammering screwdrivers down the side), new one’s best pressed or tapped in using a large socket that sits on it’s outer edge.
Probably not bolt-up, but a longer solid axle would take nuts to hold it in place(just like on those bikes at the bottom of the price range), get them from most bike shops, but be aware there are two different sizes/threads.
as coatsey said,there are two different threads,so you need the correct cones and lock nuts to suit.generally solid axels seem to have the imperial thread,and qr axles metric.this is not a constant though !
(the threads both look the same,but are NOT interchangeable)
Blimey! Is the OP another bikeradar refugee on half term?
Ha. I will admit the damage caused is my own fault! Combination of not using threadlock and not tightening the rotor bolts enough. Learnt my lesson though!
Coatsey, that would be excellent! Very much appraciated! I will e-mail you now.
They are for converting a front hub to use in the rear for better chainline one a fixie, I run one of the bolt on six bolt cogs on a 135 rear hub and it puts the chain line out on to the outer ring on a triple so not ideal but works
Posted 13 years ago
Viewing 21 posts - 1 through 21 (of 21 total)
The topic ‘Damaged rear hub. Fixable?’ is closed to new replies.
