I crashed heavily in May – the damage to me I thought was worse than to the bike (my shoulder is fecked and I’m having surgery on Friday). I had been riding my Scandal since without evident problem but I bought a nice new Soul in July – for reasons of ‘I need one’ rather than any suspected problem with the Scandal.
However, I was cleaning the frame with a view to selling it (I won’t now) and noticed this – given the characteristics of thin-walled Aluminium tubing I assume this dent constitutes an important structural weakness in the bike and it would be unwise to attempt to ride it.
Ride it until it breaks. If it does. I had a bigger dent than that in the tt of my bullit and it survived a lot of abuse and believe its still being ridden hard by its current owner.
I’ve got much bigger dings/dents in my frame and been riding it for years. Admittedly they are in the bottom bracket area which I would guess has thicker walls.
Looks OK to ride but might depend where on the bike it is and whether it could cause the tube to buckle under heavy loading. Looks like the downtube? If so you’d get some warning as the downtube is mostly in tension, with a bit of sideways bending. Top tube I’d be more worried.
It looks close to something that may fail over time. My stump jumper took 5 years to finally start cracking from a dent which had corroded. My dent did look a little bit worse. I would ride it as long as it is in a visible place that you will subconsciously check from time to time. .
I had similar in an aluminium frame a few years back, i marked the frame at the points where the ding ended, i.e. marking where the ding ended, and then monitored this to make sure it didn’t grow. In the end the frame died from another crash.
I dinted my Inbred (steel, obvs.) on the first ride, and significantly worse than that. I fell off onto the only boulder in the field. It must have been magnetic…
Posted 10 years ago
Viewing 23 posts - 1 through 23 (of 23 total)
The topic ‘Damage – I assume this is terminal’ is closed to new replies.
