You’ve ended the juvenile comments finally then?!?
moi??? Don’t think I really made any.
yes – it lived. I am actually going to send it in for a service as I managed to push the waterproof seal in at the top a long while ago – I can’t find the service fees but I seem to remember them being pretty cheap.
The bigger screen is attractive for plotting impromptu routes on it, for instance if you go to an area and buy a local cycling routes book, or if you decide to cut your route short and want to plot a route home (for which you can just set a POI and have it show a straight line to the POI so you know roughly the direction to go in).
The big buttons are nice rather than a touch screen – I wouldn’t want to use muddy fingers on a touch screen.
It is one of the newer GPS chips – I have never had a problem.
The bike mount is pretty good as well.
The main drawback is the screen covers, which protect the main screen, are not a brilliantly strong plastic, and get scratched. They are replaceable and you buy them in packs of 3, but the answer is to us the Zagg invisible shield screen covers that Satmap sell. I also have one on the main screen, but you can get moisture effects doing this.
When you pick a route you can have it constantly orientate the map to the direction of cycling so you know the turn is coming up, which is nice. You can also have it show all the other routes you have in the area in a different color so you can duck off onto another route if you want part way round.
But maybe you should look at the Garmin 800 to see if the screen is nicer as it is newer.
