LabMonkey – Member
It is always best to expend extra energy when you are moving slowly, as air resistance to acceleration is lower at lower speeds. So, work harder on the climbs and easier on the flat and descents.
This is absolutely correct in terms of required power output.
Although, as mentioned above, energy expended for the same average power may (will) not be the same for constant output vs multiple easy/hard sections, since your body isn’t equally efficient at all power output levels.
I guess as long as you don’t totally kill yourself on climbs and stay fully aerobic, then more effort on climbs where you aren’t wasting energy against air resistance would be the most efficient method.
