Polo must be what STWers try out in the summer. I tried it for the first time last week, and played my first games this week. Was really good fun, and I’m too considering my n+1.
Plenty of info on mallets online. Magic polo do ones for £45 which seems pretty expensive, so I’m going to stick an ofcut of pipe to the end of a ski pole.
My current bike is my wife’s old hack bike. It’s a cheap alloy frame, which will be stronger than most steel frames of it’s weight. It has 26in wheels which are strong and cheap.
Most polo bikes seem to have narrow bars and long stems which is a bit alien to me. I’ve currently got some Mary bars on a mid length stem, but fancy going short and short.
I find cable brakes to be a good compromise as you can easily swap the brakes from one side to the other, but that could be done with some Hydro levers with a split clamp. Depends if you want to brake with your front or rear, and weather you need to use the bike for riding off the court. I ride there and back on the road, and don’t want to kill myself by grabbing the wrong brake, but prefer using left hand with front brake on the court.
I run two gears, one low ratio on court, and one for the commute.
