Viewing 5 posts - 1 through 5 (of 5 total)
  • Cutting down carbon bars
  • andylc
    Anyone know why Raceface put a line on their bars, beyond which you’re not supposed to cut? I’ve already gone beyond it on my used to be 800mm bars but I plan to take some more off and am presumably going to die horribly.
    br
    Presumable due to how they are made/configured.
    But ignore it, can’t be important… 🙄
    prettygreenparrot
    ‘cut down’? I thought the fashion these days was ‘wider, even wider’.
    nickc
    might be that the ends are a bit more flexible, and the central part is a bit stronger, or from that point the layup is different?
    probably void the warranty if that bothers you.
    scaredypants
    maybe thinner walls, not reinforced for fitting levers etc ?
The topic ‘Cutting down carbon bars’ is closed to new replies.
