Viewing 13 posts - 1 through 13 (of 13 total)
  • Cutting down alu bars
  • slowjo
    Junior hacksaw or pipe cutter?
    I do not have a vice so I’d probably have to do it with the bars in situ?
    My gut instinct says pipe cutter but I was just wondering which generally gets the best results.
    Or would it be an ideal excuse to wander down to the local tool emporium and avail myself of one of their finest bench vices?
    cynic-al
    Pipe cutter cuts straight but leaves a flange.
    chrisdw
    Pipe cutter and a file will be neatest.
    How straight can you saw? 😉
    robinlaidlaw
    Never mind how straight can you saw, if you are any good with the file to tidy up it won’t matter what you cut it with!
    Andy-R
    slowjo – Member
    Normal (12″) hacksaw, 32TPI blade and a file to tidy up afterwards.
    gringojimi
    Slowjo, I’ve first hand experience of your DIY skills. I think you should arm yourself with a packet of biscuits and pop down to the local bike shop 😀
    slowjo
    LOL!
    Cheeky beggar!
    At least I can change a tube in less than 30 minutes 😉
    Onzadog
    I’ve always found a good hacksaw cut needs less tidying up than the flange from a pipe cutter.
    warns74
    Bought a pipe cutter and small set of files from ebay for less than £9 and they do the job perfectly with nice even cut. Chopped down 2 sets of bars and both worked really well.
    Northwind
    If you’ve got any leftover lockon grip ends, they make perfect cut guides.
    asterix
    chainsaw it then 😆
    smurfly13
    I use one of these pipe cutters
    http://www.diy.com/nav/fix/handtools/plumbing-tools/pipe_cutters/B-and-Q-Tube-Cutter-11247828?skuId=11758533
    Leaves a little flange so no filing required and never had a problem with all the bars I have done!
    zippykona
    Pipe cutter. Once you’ve done your bars you’ll be looking for other pipes to cut.
    I really did need to take an inch off my seat post.
The topic ‘Cutting down alu bars’ is closed to new replies.
