- This topic has 68 replies, 34 voices, and was last updated 7 years ago by Pook.
Cut Gate – share your feedback!
simonbownsFree Member
Ride Sheffield, Keeper of the Peak and Peak District MTB have raised concerns about the boggy bits on Cut Gate, producing a document to outline their thoughts.
We’d love rider’s thoughts on it – please have a read and feedback to the groups.
whitestoneFree MemberNot on FB so here’s a couple of my thoughts.
“Fixing” the two worst areas could, and I stress could, simply shift the problem elsewhere on the route as people then assume that the route is rideable in all conditions. In a few years’ time there’ll be calls to fix those points, effectively a complete resurfacing by stealth/parts.
Could there be “entrance tests” at either end? I.e. “If this bit is boggy/up to your axles then please don’t continue as you’ll be increasing erosion”.
Unfortunately there’ll always be some who are of the opinion that “I’ve come all this way so I’m going to do it”. You get it in biking along with climbing and other sports. Not sure what you can do about this other than name and shame which is a bit confrontational.
thisisnotaspoonFree MemberI’d vote for more flagstones. But I do think that any work is just going to move erosion elsewhere on the trail as more people ride it. Does the winter erosion of the boggy areas do irreversible damage each year that gets worse and worse, or does it exist in a steady state winter to winter? If the latter then maybe doing nothing is best with the bogs acting as a natural enforcement of voluntary restraint to using the route during sensitive times? Making the bogs passable in winter will shift erosion to other parts of the path which currently see little traffic when wet.
Fresh Goods Friday 696: The Middling Edition
Latest Singletrack VideosFresh Goods Friday 696: The Middlin...tonFull Memberridden cutgate for over 30 years. it is now better than it has ever been. the whole top level section used to be a quagmire in winter. last time I went over it was not. the work they have done seems very good, if the top what harcored it would be ideal.
BadlyWiredDogFull Member“Fixing” the two worst areas could, and I stress could, simply shift the problem elsewhere on the route as people then assume that the route is rideable in all conditions. In a few years’ time there’ll be calls to fix those points, effectively a complete resurfacing by stealth/parts.
To be fair, after the restoration work a few years back, most of the rest of the route is pretty sustainable – the worst section was fully slabbed. It’s just a couple of places that get really boggy. Personally I only ride it in a dry summer or when it’s frozen solid, but the reality is that some people don’t care about conditions and ride it whatever.
That said, I’m not sure Cut Gate is ever going to get the sort of traffic that more accessible trails do even it if is selectively restored in the currently eroded areas.
Personally I’d favour better rider education, but I suspect that’s not a viable solution.
jefflFull MemberOnly ridden it a couple of times as even though it’s local weather and timing rarely work out. As mentioned in the report there are a couple of key areas that get very boggy. If these sections of the path/trail could effectively be raised with flagstones or similar so the water/bog can flow clearly underneath then that would help massively. The rest of the trail is, from memory fairly resilient.
Heading up after cranberry clough there is a lot of flagstone which is obviously resilient. On the north side, heading down to North America is lovely singletrack. It’s generally on the side of hill so water drains off it pretty well. My only thoughts are that if more people use it you get more traffic jams as it is very narrow. I guess this is made worse by the out and back nature of the route.
As a aside, after carrying out a spectacular OTB the boggy nature of the trail does have it’s upside 🙂
thepodgeFree MemberI think the top two replies have nailed it.
People will ride it whatever the condition and if its “fixed” even more people will ride it. You can’t educate everyone and even if you could some people simply don’t care.
A fully armoured (hardcore or paving) trail would be best even if this has to be diverted off the main ROW and around bogs… And while you / they are at it have a look at the North America trail as that used to be a couple of foot wide and now its a couple of yards wide plus fix the bit by the corner of the wall as the path is boggy and unclear meaning everyone goes really wide.
TraceyFull MemberSame as Ton, been riding it for over 30 years and it was as bad then as it is now. When we have a cold winter and a bit of snow it seems that it holds up better the following summer.
Asking people to be sensible wont work, not even sure that a repair to the worst effected areas will work.
Over the last couple of years we have seen less and less bikes on a weekend so maybe riders are giving it a miss. if they do decide to repair its going to be one hell of a task to get the stuff up on to the topmondeFree MemberDefinitely no more flagstones.
I run as well as bike and flagstones in winter are a deathtrap when frozen on the high moors. If you walk from snake pass through to Kinder you will see in parts a small footpath developing next to the flags as people avoid walking on them.
Like to see one of my photos made the brochure as well..!simonbownsFree MemberCheers folks, glad to get some replies straight off.
As per the booklet, we’re looking at rider (and other user!) education first – but that’s a very difficult task.
It’s by no means a winter only issue these days, often wet and bad to ride at other times of year too. We think there’s still a lot of use (bikes and others) when it is wet, hence the growing boggy sections. I don’t think enough people are avoiding it when bad. That’s not necessarily intentional, hence my point of education.
The previous work by Moors for the Future has done a cracking job, agreed. It’s meant that most of the route is good, but then contrasts heavily with the really wet bits.
I think the tide is changing a little, with riders now paying some attention to what they ride and when. There’s still a big (probably growing) group of people who are used to trail centre/all weather routes and don’t question a route guide on a website (for example)
cyclelifeFree MemberRode it once a few Summers back, couldn’t see what the fuss was about, there’s loads of better trails and circular routes in the Peaks, so I give it a miss.
Agree that addressing the issues would be good but not sure what can be done apart from turning into another trail centre type surface 😈tonFull Memberon a dry summers evening, it is one of the best trails in the whole of the uk……simply stunning.
but now knowing what it get likes in winter, I would sign myself up to a voluntary self imposed ban from riding it.
AlexSimonFull MemberFascinating subject. I don’t have any answers, but very interested to read other’s thoughts.
My personal thoughts.
Flagstones are bad in general.
The work done so far on the top on the areas that aren’t flagged is excellent.
It’s never going to be a super-accessible path, so there’s no point in making it so.
‘Superbog’ does probably need something done as the path is getting wider and wider. Interesting that people above think that it will just move the problem elsewhere. It’s not something I’ve noticed in other areas.ebennettFull MemberMight it be worth trialling a “We recommend you don’t ride Cut Gate this weekend” post on KoftP when it looks like it’ll be bad (based on recent local weather and experience)? If no-ones posted up conditions during the week and you’re planning on riding on the Saturday it’s kind of a guessing game if you’re not in the area to know what the weather has been like.
Don’t know how likely it is that the ones who ride it in poor conditions will check KoftP, or if would even make them avoid it, but couldn’t hurt to try?
DickyboyFull MemberSignage might not put everyone off but might help with non locals riding when not appropriate – i certainly would have found another route rather than taking a group up there a couple of years back if I’d known of the issues
whitestoneFree Member@AlexSimon – the problem moving elsewhere may or may not happen, it’s hard to say. I’ve only ever done Cut Gate twice, probably ten or fifteen years apart and I can’t remember what if any difference or degradation there was.
A quick check on Strava segment explore shows about 6000 attempts which IME is a high number for a natural track, it’s about the same as Jacob’s Ladder, a bit less than The Beast and half that of Potato Alley. If those numbers are correct then it’s getting as much use as a stoned surface track.
Richie_BFull MemberPaving or partially paving Cut Gate would seem ruin its point (A bit like the Pennine Way). At the moment this is the only legal route across the moor so its quite heavily used. There are two other bridleways across from the Strines Road (Foulstone Road & Dukes Road) which are downgraded to footpaths once they hit the watershed or county boundary. The gap between Foulstone Road & the shooting tracks on the derbyshire side is perhaps only four or five hundred yards. Dukes Road can be a bit of a boggy mess by the time it reaches the watershed even in the best of conditions (but then again so does Cut Gate for much of the year).
Opening up one or both of these routes could significantly lower the pressure on Cut Gate.When the Right to Roam legislation was brought in 16 years ago the Peak Park Rangers were insistent that the discrepancies where bridleways get downgraded to footpaths at county boundaries or where old cart or quarry tracks were classed as footpaths would be addressed but that never happened.
thepodgeFree MemberThere is some serious naivety on this thread:
KotP is an excellent service but very small considering the UK riding population and you’re likely preaching to the converted.There are very few alternative routes up there so no virtually no one is going to ride part way, see a sign and then turn back, its mountain biking, its supposed to be muddy and difficult and a bit of a challenge.
“We” are mountain biking enthusiasts, were talking about a bike group that have produced a guide about a biking route for and posted it on a biking website. We need to be thinking about the tens if not hundreds of thousands of others that have bikes not ourselves.
And that’s where this seems to be heading, fixing the issue for everyone, not just the enthusiasts.
BrownFree MemberI’m not a fan of more flags. Half the attraction of the top section is the peaty moorland feel.
And it’s hard to give way to walkers on flagstones. You end up stepping off them anyway.Education and signage gets my vote. Has a knock-on effect for other fragile areas too.
stilltortoiseFree Memberand posted it on a biking website
…and emailed it out to representatives from across the spectrum, including the Chief Executive of the Peak District National Park, councillors, county councils, various media, horse riding groups, disabled groups, access officers etc
Great comments. Keep ’em coming.
mildboreFull MemberAny possibility of improving drainage? There’s 3 main boggy points, all relatively short. I’m no groundsman but wonder if raising the path with drainage pipes under might create a usable/sustainable track
thepodgeFree Memberstilltortoise – …and
Fair point but what I mean is self regulation is very limited.
Its good to see “us” branching out into cross discipline improvements.
ebennettFull MemberWould it be possible to go data mining on Strava to help with this? If you could get user names for people who ride it when conditions are poor you could maybe message them to take part in a survey to understand why they’re riding it and what you could do to encourage them to use alternatives.
Not sure if that’s even possible with Strava and it definitely won’t capture the whole user group, but it would be a start and could maybe be followed up with someone taking a survey at the trail head (not volunteering btw 😀 ).
Edit – could maybe get some undergrads to do the survey as part of their thesis. We seem to get quite a few on here asking for input into surveys so there might be a way to make it worthwhile for them as well.
ajfFree MemberI think any plans need to take in other user groups. For instance last weekend there was a fell race that was an out and back along Cut Gate. Thats 200+ across it in a day there and back. So 400 journeys on a wet Sunday in Feb.
I think it is also a well used track mainly because it is a very convenient way into the main of the peak district from the northern edge. More access to ridable trails and bridleways that lead in a similar direction would lead to less erosion and less traffic. I suspect a lot of the traffic is because it is a means to an end.
With regards to preventative measures, no to flags! Re-enforcing and raising sections with aggregate and more drainedge round the side would be good (not sure how easy).
christhetallFree MemberFirst of all, well done to all those involved in the production of this leaflet – excellent work and was well received at a BMC meeting last year
Personally I only ride Cutgate in the height of summer – partly due to a history of crashes, problems and other issues that has ensured that every time I’ve done it I’ve had an epic, but that’s another story. Because I live in Sheffield there is no need to me to do it when it isn’t in good condition.
But I’m a bit concerned we could take this self-regulation/self-restriction too far. Look at a map of Bleaklow – that’s the huge tract between the Woodhead Pass and the Snake Pass – a Cutgate is the only way across it for MTBs. There are a few other trails that nibble at the edges – and those two dead end bridleways – but essentially it’s a bike free zone. You go for 9 miles due west of the summit before you hit a road and there’s no legal trails in between. Even to the east it’s 3 miles.
So I think it’s important that we do something to make it more viable for more of the year. And that means that when people go up there there isn’t a drought, they don’t deviate from the tracks to go round the bogs. This applies not only to cyclists, but also walkers and runners.
When I was up there in August last year it was mostly bone dry, but the bog of doom (as in seen in the pictures) was really bad. Not sure whether boards or flags are the answer, but we need to do something before the path gets half a mile wide at that point. Main thing is to improve drainage, but of course the mud is so think that it blocks ditches really quickly. But apart from that there was only one other dodgy section along the top – a vicar of dibley hole where I had an OTB the previous year – along with some boggy sections near slippery stones (where drainage ditches had been dug, but had got blocked).
ifindoubtflatoutFree MemberAs a local to Cut Gate and a regular summer user my personal opinion is that it would take More than just slabs to cure the swamp problems up there. The slabs would just end up sinking over a period of time thus being a waste of time and money. As for a solution to the problem the only way I can see would be to move the path to the higher ground on the right, but then you would be back to square one again in a few years time when the new path turns to a bog. I would love to see a solution to the problem as it’s one of my favourite summer evening rides.
mickmcdFree MemberIm wondering why its even being looked at , the guy I live next to is the gamekeeper up from langsett to midhope boundry and then Magnus is the actual keeper from midhope to the rocks before you start to drop down, they both say this land is privately owned and not by the peak national park so who actually does have responsibility
In fact he just gave me the names of both landowners who run the shoots up there
ridesheffieldFree MemberCheers fo all the useful comments. Just a couple of things to add onto here.
This may be mountain bikers taking the lead and starting the conversation, but the idea is to get all user groups and landowners onboard to come up with a solution that works best for all.
The main focus is the two deep bogs which have deteriorated noticeably over the past 5 years. It is expected that these two spots would be sorted professionally. The rest would not see masses of work as no one really wants to see its character change. But there may be some volunteer trail days just like Ride Sheffield and Peak District MTB are already doing.
This is just the start and it’s really important that we can listen to everyone’s thoughts on this. Keep the comments coming and thanks again!dannyhFree MemberThis one might be controversial, but I say “leave well alone”. The really horrible bits are probably max 50 metres. If we go kicking up a fuss, we could easily focus unwanted attention from those who will use any stick to beat us with.
Also, sanitising it will inevitably lead to it becoming more accessible, not always a good thing. The more people you encourage to ride (or even walk) it, the more likely you are to get a mountain rescue situation as you will be making it more accessible to people who are unprepared.
It is a wild ride, in the best non-gnar sense of the word. A classy trail with a real element of committing to it and remoteness.
Also, hauling equipment and materials up there may well lead to the existing trails being ‘improved’ to facilitiate this.
I love the work that PDMTB and others have done to the likes of Lockerbrook and Whinstone Lee Tor, but that has been addressing erosion caused by heavy traffic on trails that are popular no matter what the conditions. Cut Gate is an oddity in that it really isn’t something you just ‘pop out’ to ride or come across by accident. The bog at the top is pretty much a natural feature from what I can see, just a consequence of the ground leveling off with water coming in from the right (looking northwards).
Please, just be careful what you wish for. Some places are wild, committing and not always ‘fun’, but this sometimes adds to their mystique. Not everyone needs to be able to pedal or ride their gnarpoon for 100% of the ride to enjoy it, and we could end up with unintended consequences.
mickmcdFree MemberThis one might be controversial, but I say “leave well alone”.
i sit in this camp to be honest
The problems I hear about, happen much lower down the trail where other users frequent those trails and are more to do with idiocy in the countryside than erosion most often in summer , yes people will light a barbecue on moorland
people will let their dog go wandering off to see the grouse chicks/lambs despite the signs to keep your actual dog off the frigging moor completely
luckily this is usually winter time so getting the landowner pissed off and everyone banned even though its not our fault yer honour might fix the bog problem anyway for those 6 months,
However seriously i think your looking from the peak district proper side from ladybower over and back , rather than our side of the hill where to be honest lots of us go up cut gate regularly but also spend lots of time up winscar, hade edge etc
its like anything publicise it and they will come but its been classed as a classic ride for the 25 years of my life ive been riding there and not much changes up there despite the numbers which seem pretty constant unlike wharncliffe where the numbers seem to explode on a sunday you can still go out and see no one all day and on others theres loads even when it wragging it down.
and in winter when the
simonbownsFree MemberThanks folks, appreciate all the comments. As Stilltortoise and RideSheffield say, the whole point is to bring other user groups/stakeholders together to start a discussion.
This document has been VERY well received by Peak Park, alongside Moors for the Future who did some of the previous work on Cut Gate.
There’s lots of sides to this, including user education.
Mick- I think your points about other problems (idocy in the countryside) are valid too, that’s a slightly different side to things but does link into user education.
simonbownsFree MemberHere’s a direct link to the booklet.
(I’m not entirely convinced that everyone has read this before commenting) 😉
slightreturnFree MemberAgree with above poster. But could they not create a raised platform area over the worst areas at the top. Even get the’ nair do wells ‘ doing it on community service, paying back to society and gaining skills for potential work/jobs later.
This should throw the moggys amongst the pigeons.
markshiresFree MemberI agree with slight return could a raised platform/ bridge be built over the big bog on the top, it’s been done in other parts of the Peaks. I know the Langsett side mostly and other than a couple of bits on the top, I can’t really think of any other parts that are too bad, it’s mostly rock isn’t it?
shifterFree MemberI’m a once a year Cut Gate rider so I doubt my opinion counts for much but, I’d rather ride it as a loop. If those bridleways that turn into footpaths can be regraded then I only pass through the bog once.
I realise I’m asking for the earth, but you did ask the question.PookFull MemberMickmcd, those contacts would be really helpful if your neighbour doesn’t mind asking them to get in touch with PDMTB or RS.
This is a great discussion already, thanks everyone for your thoughts.
On Danny’s point, the idea is absolutely not to sanitise. In fact the real aim is to avoid the damage up there and avoid us being blamed.
On the education piece, we’re already working hard with the mags to improve things on that front. Always can do more though
thepodgeFree Membershifter – I’m a once a year Cut Gate rider so I doubt my opinion counts for much but, I’d rather ride it as a loop. If those bridleways that turn into footpaths can be regraded then I only pass through the bog once.
I realise I’m asking for the earth, but you did ask the question.Serious question but as we know the world wont end if you ride footpaths, why don’t you use those footpaths and ride it as a loop?
It seems little odd to me that if exactly the same path had a different name some people would treat it differently.
shifterFree MemberIt’s been known but it’s something I usually avoid. If everyone did that it would protect Cut Gate but I don’t think it would do much good for the mtb profile in the Peak.
chakapingFree MemberI’ve only ridden it once, when it was dry and firm in July. The education must be working a bit, as I’ve avoided it due to likely boggy conditions on all subsequent visits to the Peak.
I’d vote for an aggregate track rather than flagstones, for aesthetic and safety reasons.
Brilliant work with that document Simon, it’s a breath of fresh air. I’m gonna drop you an email about something a bit related to it.
thepodgeFree MemberYou might want to drop Pook an email too, I believe there is quite a bit of his work in there.
The topic ‘Cut Gate – share your feedback!’ is closed to new replies.
