Hi guys,
I’m in desperate need of some advice!
Currently riding a cube reaction hard tail, I’ve decided to take the plunge and upgrade to a full suspension. After much deliberation, I’ve settled on a Cube Stereo 160 super hpc 2014.
However, I do not know which frame size to go for. I’m five foot nine, and have a 29 inch inside leg, so it’s between the 16 inch or 18 inch. According to cube’s inside leg calculation, I should be riding a 17 inch frame size! I then started to look at online bike stores for their view, and some say I should get the 16 and others the 18! I even went into two different bike shops, with one saying I needed an 16 and the other saying 18!!!
I thought I had it solved when one web site referred to the ape index if your in between frame size; go for the larger frame if you have a positive ape index, smaller frame if negative. Guess what, my height is exactly the same as my armspan, so the index is neither positive or negative!!
This is driving me mad now cos I don’t want to spend £3k on a bike to learn three months later that I got the wrong size. Some people, websites etc suggest going for the 18, others are saying that the cube stereo is slightly larger than the indicated frame size, so to go for the 16 inch because in reality it’s nearer a 17 inch!
If anyone could help me decide on the right size, I promise them a pint and a steak dinner!
Any responses will be greatly appreciated.
