Replacing the pivot bearings (under the shock) bearings pressed in either side with stud through the middle. Anyone got any experience on removing these bearings? do i tap out the the centre stud? will it shoulder out the bearing then tap out the other from the inside? Have had a taster tap and it seems tight.
Anyone any help please.
shireswhitmore@btinternet.com
Posted 13 years ago
Viewing 1 post (of 1 total)
The topic ‘Cube pivot bearing?’ is closed to new replies.
