zippykona – Member
The smallest one is about 5mm. If thats any use email me your address and it’s yours for whatever you want to pop in a charity pot.
If it is 5mm that works out as 0.2″ so will gladly donate to a charity of your choice 😀
Will send you an email shortly if that’s ok? Thanks.
daveh – Member
I think the smallest in that pic is the 0.4, details here. PUSH transformed the shock, far better small bump compliance, better mid stroke support, bottom out roughly the same. Not cheap though, think it was around £160 (gets a full service at the same time). As it’s a custom tune you can ask for whatever characteristics you like
Cheers Dave, will take that into consideration. I was probably going to order the inline from TF so will see how the spacer works out before I speak to them and decide which way to go. Thanks again.
renton – Member
Curious as to why you can only use the smallest one ?
If you follow the link Dave posted above, not all shocks can use each spacer. I’ve been told that with my shock I can only use the smallest spacer.
