Viewing 8 posts - 1 through 8 (of 8 total)
  • Crud Catcher Bosses
  • sneakyjean
    Want to drill & fit Crud Catcher riveted bosses to u/s of down tube – who can do – any ideas?
    zokes
    Use the elastic band thingy they come with?
    stAn-BadBrainsMBC
    this may noy be as straight forward as it seems – depending on the tubes used to build your frame, the wall thickness may be too thin due to the butting/tapering of the inner wall.
    That said it is a fairly straight forward task for a frame builder to perform Ellis Briggs at Shipley do it for app. £15
    ELLIS BRIGGS
    whereas Bob Jacksons would charge double that
    Edric64
    You have been given advice on this today already,it’s a bad idea but fxxk your frame up if you want to
    shortcut
    It’s a good idea if done by a frame builder properly. You will probably want a respray after too.
    My advice.
    Don’t bother unless you want to drop over £100 to get it done properly.
    ssboggy
    Buy my Pace RC305 as it’s already got crud catcher bosses on it 😉
    Cougar
    Use the force.
    TooTall
    I’m failing to see what the problem is with the rubber loop you get with it? Never, ever had a problem with it on any bike, ever. Or are you trying to over-engineer a solution?
The topic ‘Crud Catcher Bosses’ is closed to new replies.
