I have a pair of the very first old school Mavic Crossmax wheels and need to remove the freehub body, but am at a bit of a loss how to do it.
Unlike the modern crossmax wheels where the non drive side axle end cap is screwed out with a 5mm Allen hey, then the drive side retaining screw is removed by placing a 10mm allen key into the axle, and the freehub comes straight off. There doesn’t appear to be anything in the axle to accept a 10mm allen key in these wheels, and any way to stop the axle from rotating to remove the drive side retaining screw.
Am I going mad and there should in fact be the corresponding hex in the axle to accept the 10mm allen key, or is the freehub removal different on these old wheels.
