I considered it S8tan but would require extra poles surely? Otherwise I’d have to guy it a loooong way away to achieve anything useful. Will give it a try though.
It was the bearbones post which I pinched my ‘dropped tail A-frame’ from and was planning on trying the half pyramid as my first attempt at the A-frame did feel a bit enclosed.
Worth learning a few knots as well (if you don’t already): bowline; trucker’s hitch; taut line hitch.
I know at least two of those from setting up some basic cooking tarps when we were hiking in Canada, will check out the third.
lso, i’m not sure if you can do it with the smaller tarp but you can create a small a-frame tent using 1/3 of the tarp as the floor then a-frame the remainder.
Yeah, the 3.5 is way too small for that, I went small as I didn’t want lots of material flapping around if I’m trying to pitch on a summit somewhere, if I’m camping down low I’ll probably still use my tent.
a tarp and a bivi bag just seem like a much poorer alternative to a tent, or am I missing something?
The one time I’ve slept under a tarp (just a plastic sheet slung across two logs) it was waaaaay more pleasant than being in the tent, the feeling of having more space and the extra ventilation was great.
Also, for a high summit I wouldn’t want to pitch my Laser Comp as it gets really loud and flappy in the wind, and also there’s no guarantee of a perfect pitch for it.
Finally, I just want to try something new 8)
