Managed to build up a bike with 175mm on the left and 172.5mm on the right (don’t ask, too many ‘spares’ in the garage…) and never noticed for a bit, though imagine it’d knacker your knees if done longer term.
Fair chance you’ll not notice 2.5mm, but are you only clipping the wheel by 2.5mm or less?
Also – will mtb cranksets fit with a road type Hollowtech II bb? If so it widens my options for finding something cheap and nasty to try out before committing to something expensive.
With a couple of spacers you’d find on the equivalent mtb bb either side it should fit, though that might not leave enough thread inside the frame. Whether the cranks would work on a cross bike, I’m not 100% sure, the inner granny ring/granny ring bolt tabs might catch the stays.
Alas, it’ll be try it and find out. No definitive answer.
