Viewing 4 posts - 1 through 4 (of 4 total)
  • Crank puller question (Raceface-ISIS-Sq Taper)
  • DezB
    I need to get my'09 Deus cranks off using a crank puller as the puller cap is knacked.
    The puller cap had reverse threads right?
    So my old square taper puller isn't going to work is it? Cos that hasn't got reverse threads.
    So is the standard ISIS puller reverse threaded then?
    (I ask as I know I've used mine for Octalink and I'm surprised ISIS is different)
    cheers.
    bassspine
    should be a right hand thread as usual. If the end cap was creamcrackerd, go careful as you put the extractor in…I've never come across an anticlockwise/lefthand thread in there for a crank. (I have worked as a bike mechanic for over 7 years)
    Thanks bassspine – this is the reason I think its reverse thread:
    Mine was blank, but the replacements have this printed on them…
    bassspine
    you learn something every day – blimey that's wierd.. bet they make an insanely expensive puller too.
    Maybe they're italian!
The topic ‘Crank puller question (Raceface-ISIS-Sq Taper)’ is closed to new replies.
