Viewing 14 posts - 1 through 14 (of 14 total)
  • Crank lengths
  • ruminant
    Morning all
    Hopefully a simple question.
    I currently run 175mm crank arms, been offered some new ones at decent money, but they are only 170mm. Will 5 mm make that much difference to my bike and the way it rides?
    is there any benefits to shorter cranks?
    cheers
    simon1975
    No.
    Depends how long your legs are!
    davidtaylforth
    I am 6'2 and have to run my seat at around max height.
    I found with 170mm cranks I had to run the seat a little higher, so i swapped back to 175mm cranks.
    ruminant
    I'm 6'2" with a 32/33" inside leg
    suppose I just crank the seat up 5 mm to compensate
    simon1975
    Sounds like your legs are long enough to drive 175's, but you'll probably be fine with 170's. Shorter cranks are supposed to be easier to spin fast.
    ruminant
    David – so it threw the way you felt on the bike out alot then?
    ruminant
    aye have no problems pushing em round, will be running just the middle and inner plush bash. not so bothered about cranking out some speed
    simonfbarnes
    at first this sounded crazy but then I realised the lower pedal is nearer if the arm is shorter 🙂
    scaredypants
    unless you're the kind of person who can't get to sleep if there's a pea under your mattress, I doubt you'll notice
    I can't feel any important difference between 165 and 180 – and neither makes me a pro-level rider so there's clearly nowt to the "power" theory
    coffeeking
    I have run 165 and 175 on the same bike, with the same gearing, that's pretty noticable back to back.
    BigJohn
    My commuter bike has 170s
    My mountain bike had 172.5s but it now has 180s
    I can't tell the difference but I like to think the 180s make it easier to get up hills singlespeeding.
    It's just the emperor's new chainset.
    simonfbarnes
    I had different lengths either side (170/175) and couldn't tell 🙂
    davidtaylforth
    Not alot, but the seat was being run at about max height anyway, so i couldnt really put the post any higher to compensate for the shorter cranks.
    Also, if you run the saddle higher to compensate, it means its a bit more (5mm?) in the way when your riding downhill.
The topic ‘Crank lengths’ is closed to new replies.
