Hi,
I have recently bought a Commencal Meta SL frame and I am getting a little confused about how to set up the dual-ring setup up front.
I need to get some cranks that are going to work with the BB91/92 press fit bottom bracket (Hollowtech II) but I am unsure of what cranks to get. Everything comes as either 68/73mm or 83mm but my shell is 92mm. I put my existing Saint cranks which are 83mm axel and there seems to be alot of exposed shaft on it as there were to be used with external bearings not internal, press fit bearings.
So, does anyone know what cranks I can run with this setup? There will be working with a Shimano SLX M676 Front Derailleur Direct Mount – double.
Any help would be much appreciated, I am muchos confused!!
Tim
