- This topic has 43 replies, 24 voices, and was last updated 11 years ago by jameso.
Crank arm stiffness – Middleburn vs Hollowtechs
jamesoFull Member
Those new Middleburn XC monos look lovely. Nice spider design. I’m a fan of Shimano cranks for stiffness, how do Middleburns compare? This is for a SS and I know there’s debate about how much ‘it matters’, I just don’t like flexy kit. Got 770 XT and 980 XTR currently.
Anyone used both to compare? (Tazzy you haul on the SS and use Middleburns right?)
cynic-alFree MemberI think there’s also a debate about how much actual (as opposed to perceived or believed) difference there is, the last test that measured crank flex showed that even Saints weren’t that much stiffer than ST shimanos (tho IIRC Middleburns were even flexier).
jamesoFull MemberWhere was that test Al? Thanks.
I can feel a fair bit of twang in some sugino square taper road cranks I have, and none noticed in my Shimanos. Just wonder where Middleburns sit on the scale in between since they look pretty skinny.
xiphonFree MemberYour wheels and possibly rear triangle will be flexing long before your cranks.
jamesoFull MemberThat old chestnut ) It all flexes as a system based on stiffness in different areas and where the forces are. And lets say I already have a stiff wheel set, frame, stem, bars etc.
NorthwindFull MemberWMB did a deflection test on a load of cranks a while back, but not sure if they had a middleburn in it. I thought the 7s felt pretty dang flexy, and that’s something I’m normally oblivious to- I can’t tell any difference between my weightweenie Noirs or my old Saints. But these things are so subjective, it could just be in my mind as I’m a h8er 😉
CheezpleezFull MemberI use both Middleburn RS7 (on a rigid 29er SS) and various Shimano and Raceface external bearing cranks on geared 26in hardtails and FS bikes. The Middleburns *must* be flexier but I can’t say I’ve ever noticed while riding or been bothered by it. As said above, it stands to reason that tyres, frames and wheels will flex long before a crank.
breatheeasyFree MemberWMB did a deflection test on a load of cranks a while back, but not sure if they had a middleburn in it.
If its the issue I’m thinking of then, yes, they did have Middleburns in it, though it might have been the X-type ones.
If I do remember correctly the difference between the proper ‘noodly’ chainsets and the stiff ones was so minor (possibly less than 1mm) that I’m not sure people really would notice a difference out on the trails.
DezBFree MemberAs said above, it stands to reason that tyres, frames and wheels will flex long before a crank.
Wheels, frame, tyres, soles of your shoes.
How much more can one crank flex than the other, really?umop3pisdnFree MemberST cranks have a much smaller axle than HT2 cranks, so are gonna be flexier
messiahFree MemberThe stiffness of the Middlebrn cranks never bothered me but the way the crank arm protruded and rubbed my shoes/foot near my arch had me hating them… but this is a while ago and think they were RS3’s but the current designs look similar.
jamesoFull Member1mm of deflection doesn’t sound like much but it all depends on the load needed to do it. All I’m really interested in is whether it’s noticeable under SS type hauling, especially when fitted to the kind of bike that will show up a flexy crank, bar etc. If in doubt.. probably best sticking with Shimano.
unovoloFree MemberI went from a set of Octalink Deore cranks to a set of Middleburn RS7’s.
Lovely looking crank but I got rid quite quickly as when cranking in the big ring something was definetly flexing/moving causing rubbing on the front derailleur cage.
All bolts,chainring bolts etc torqued and tight,everything adjusted correctly,no problems with gear shifting but definite rub/flex.
Now have set of Kore ext BB cranks and no noticeable flex and definetly no rubbing.
Got Raceface cranks on my roadbike no probs there either, and got a set of old Shimano 600 cranks on my SS which may flex but as theres nothing to rub on i havent really noticed.T1000Free MemberIt’s v difficult to do a meaningful comparison between rs7/8s and other brands unless using the same BB
Comparing an X type to ht2 hone lx and xt I can’t tell the difference…. Apart from the finish and far superior preload adjuster…….
mrlebowskiFree MemberYou’ve got to be cranking out some watts to notice ANY flex at all. I know a few fast boys & have had this discussion with them – they said it was almost impossible to notice any flex at all. I certainly can’t & my power is 200w at lactate threshold & 300w at CP30.
I’m not saying you aren’t stronger but are you sure it’s not in your head? Perhaps it’s something else on the bike that’s flexing as has been suggested..
jamesoFull MemberI’m just asking to see if there’s any general opinion, don’t know much about non-Shimano cranks from my own use. Not saying they actually are flexy as I’ve not used them.
300w at CP30
– I have no idea what that means sorry ) I don’t think you need to be a racer to notice flex in things, just a perceptible rider of reasonable strength / weight etc. It’s not because I’m a Hoy-alike or anything but it’s not hard to feel the arms flex/twist on a skinnier crank. Hard to say from looking though, I have some old Dura-Ace track cranks and they feel pretty solid.
ClobberFree MemberI can out put out over 1200w for brief spells and use Middleburns for my singlespeed so I really don’t think you need to worry about them. I really like them and will be buying my third set very shortly.
mrlebowskiFree MemberI don’t think you need to be a racer to notice flex in things, just a perceptible rider of reasonable strength / weight etc. It’s not because I’m a Hoy-alike or anything but it’s not hard to feel the arms flex/twist on a skinnier crank.
My point is you do actually to be really quite strong to get crank arms to flex, I mean really, really quite strong…
You would certainly need to be putting out power a fair way beyond that of your average rider. Ask yourself this: “Are you the quickest in your group by some say or just keeping up or something else in between?” If youre not the quickest by some way then I would suggest that its in your mind – as you wont be making the power needed to get the cranks to twist.
Anyway, your money & your choice. Just offering some advice.
Ps CP30 is a Critical Power test performed as a maximum effort for 30 minutes. Its a reasonable measure of your sustainable power. The tests can be longer or shorter. Its very unpleasant..
thisisnotaspoonFree MemberI’m not the quickest in any group apart from the slow one, although I’m not usually the slowest and definitely not the lightest. I can definitely feel the difference between my basic truvative ST’s and old deore HT1’s. And there’s a difference between my Deus, XT, XTR and Saint chainsets.
There’s so much flex that it’s bad, but there’s enough that you can feel it.
doof_doofFree MemberThis gives an indication of the magnitude of arm flex:
http://fairwheelbikes.com/cycling-blog/products/fair-wheel-crank-test-4.html
thisisnotaspoonFree MemberThat’s actually much more than I thought (0.1-0.3 inches), although it didn’t measure whats more noticeable, the deflection of the pedals rather than the chainring.
paulosoxoFree MemberErrrrmmm
Before cranks start flexing does the plastic of your (road) cleats, sole of shoe, foot, ankle, knee not flex/compress a bit more before the actual cranks start to bend?
ClobberFree MemberThe whole bottom bracket area flexes before the crank arms for me….
NorthwindFull MemberShould go without saying that other stuff is flexing, but, that doesn’t mean it’s not relevant. When I tried them it was on a scandal- I had a scandal at the time with SLX on it so a very straight compare. And yeah, I’m sure there was a difference, and it felt different from frame flex- pedal seemed to squirm a little underfoot.
The same thing’s noticable on my commuter, which is a pretty stiff old mtb but has supercheap shimano squaretaper cranks on it. Much worse on that, naturally! But does make me more convinced that I didn’t just imagine it on the middleburns.
(I have an old Soda which flexes like a bedspring, but it’s Nice Flex. Cranks feel like Bad Flex.)
epicycloFull MemberI use Middleburns on all my singlespeeds without any problems.
I reckon the pedal axles will be flexing long before the crankarms.
bwaarpFree MemberI’ve never quite understood why crank flex would affect handling. Other than for jumping/manualing…I don’t really use my feet as such for controlling the direction I’m going in….I use my legs, hips, torso, shoulders, arms, hands and head.
Pedals have always been there as simply something to stand on.
cynic-alFree MemberAl you who can DEFINITELY feel the difference, have huge power outputs, “reckon” this or that…
Do I need aracer to come along and tell you how poor the human body is at measuring stuff like this?
Did you do double blind tests?
Did you isolate the crank in a solid mounting, apply specified loads then measure its flex? Or did you just ride some bikes, with different frames, tyres, tyre pressures etc yada etc..?
jamesoFull MemberAsk yourself this: “Are you the quickest in your group by some say or just keeping up or something else in between?”
I have ) and I know why I want to know. Sorry, don’t mean that to sound dismissive. I was just asking for feedback from anyone that’s used them who has an opinion. A fit racer is not always a powerful or perceptive rider and an overweight gear masher can be a good test rider )
mattbeeFull MemberMiddleburn on my singlespeed and my 5 Spot. Both on square taper.
The 5 Spot was previously XT external BB setup. I haven’t noticed any difference in flex although I know there must be different levels of it.
The only times I have ever noticed flex in the crank/bb were when using an FRM Ti bb and when I was running Cook Bros RSR with a Hope BB. Both led to creacking andc chain rubbing on front mexh but with RS7, UNO ring and UN72 on both atm I couldn’t quantify it.
I am6’2″ with 34″ inside leg and size 11 feet so I have fairly big levers to turn the cranks with…clubberFree MemberNot directly on topic but…
at uni (mech eng), one of the projects was to work with Middleburn to improve the fatigue life of their cranks to get through the (IIRC) JIS tests.
The guys in the project team (which included mtbers) were pretty unimpressed with Middleburn’s engineering skills which seemed to consist of testing a part until it broke then sticking a bit more metal on where it broke. I’d be interested to know how much they’ve progressed since then becuase otherwise, it’d explain why Middleburn cranks ‘feel’ a bit flexy compared to better engineered products.
FWIW, I’m pretty confident that I can feel the difference in crank stiffness if there is a significant difference. Whether that actually makes me go faster/slower is very debateable.
example: see the slightly pointy bit of metal on the crank directly opposite the main crank arm – that was added because they used to crack there.
epicycloFull Memberclubber – Member
…The guys in the project team (which included mtbers) were pretty unimpressed with Middleburn’s engineering skills which seemed to consist of testing a part until it broke then sticking a bit more metal on where it broke…I find that encouraging.
So we can take it that there’s no more metal on a Middleburn than there needs to be. 🙂
Actually surely this is just as valid a method at arriving at a solution by calculating it and then still having to do trial and error testing? (So long as the customer isn’t the guinea pig).
NorthwindFull Membercynic-al – Member
No you’re right enough, it’s impossible to know anything without proper testing. What’s the weather like? No point in even asking really without lab testing 😉
Comparisons- replaced my nice ancient shimano with crappy nonseries cranks, all other parts on bike the same. Bit of an extreme example tbh.
Comparisons- SLX vs Middleburn, both on Scandals with fairly similiar kit. Of course other parts are different but I don’t see them producing the same effect…
it’s not some loss of power or vertical squish I (believe I) can feel, tbh I’d be oblivious to all that even if it was in isolation… it’s twist in the arm (and maybe axle?) which equates to the pedal twisting/moving off the horizontal. And the human body is quite good at detecting this sort of thing, it’s how we stand up on slopes and shifting surfaces. If you stand on a floating pier you feel even the smallest swell frinstance. (if a pedal axle comes loose I notice it instantly but the play is very small) Probably would also be more pronounced on flats than SPDs for much the same reason?
Now all that said- it’s never a problem, not to me anyway. Bikes do lots of things that are interesting but not really important.
tazzymtbFull Memberand an overweight gear masher can be a good test rider
you called?
from my experience and moshing the hell out of SS kit and making very non flexy things go all noodly, I can say that I don’t notice a massive(if any that I can say is definitively crank flex) difference when compared to xtr hollowtech and things like rotor Agilis and E13 cranks. I have decided that I don’t Like Ti bottom brackets though as from a purely subjective point I know I’ve saves weight but my brain tells me it feels odd under full maul.
clubberFree MemberSo we can take it that there’s no more metal on a Middleburn than there needs to be
Not really. There could well be material being used that adds little strength/weakness or small amounts that could be added that would significantly improve them (by 3000% AWESOMZ!) 😉
SpeederFull Memberclubber – Member
…The guys in the project team (which included mtbers) were pretty unimpressed with Middleburn’s engineering skills which seemed to consist of testing a part until it broke then sticking a bit more metal on where it broke…Even if you’re using FEA, that’s all you do. It’s empirical engineering same as has been done in developing anything for thousands of years. FEA just offers you a shortcut as you can obviously just bend them virtually and see where the hot spots are. Doesn’t mean you wouldn’t have to build one to prove the results though
clubberFree MemberAbsolutely but it was the nature of guesswork that suprised me. As I said, it works but it’s not a very effective way compared to what they could have done.
OrangejohnFree MemberChanged over to old style Sq taper Middleburns (RS7) running on a UN55 for my single speed and noticed no difference whatsoever to previous/current External cranks (Shimano/ Middleburn).
Love the look and love the fact they are made in the UK.A friend uses RS7s for trials riding and wouldn’t use anything else; whilst I have no knowledge on the subject I wouldn’t have thought he would be using them if they were flexy.
T1000Free MemberOrangejohn + the trials guys value their nads……the warantee includes competition use for the 7’s…….
The topic ‘Crank arm stiffness – Middleburn vs Hollowtechs’ is closed to new replies.
