Viewing 3 posts - 1 through 3 (of 3 total)
  • Cove hummer
  • quattrozampe
    I just bought a 2009 cove hummer on ebay. How do i determine its exact year. There is a number looks like 110311 then underneath 18. This is under bottom bracket.
    Also i was thinking of putting on a set of on one cabon forks for road riding as i have two bikes and i want to use this to go out with a friend with a road bike. These carbon forks are 440mm axle to crown which i think is equivalent to 80mm suspension forks. Will this be ok or would there be problems as cove recommend 100-130 suspension forks?
    Any advice welcome or thoughts.
    tonto
    would be ok if you put a 29er up front 🙂
    quattrozampe
    Thanks but the bike turns out to be a bit big 18inch but prob need 17inch so thinking shorter fork will lower it a bit. Would the 26er fork at 440 work? More aggressive position i know but any downside?
    Dave
The topic ‘Cove hummer’ is closed to new replies.
