Nick,
Excellent. New you would enjoy it. The HJ is built for 'Hidden Valley' on the Penhydd.
All the best.
Nick,
All the best.
1981miked....Don't sell it!....unless you have to of course.
I'm only 1 ride into my ownership of mine but i absolutly love it (so far!). I bought mine to ride my local wooded singletrack but found it great fun at Afan today.
I love my Orange 5 Pro too but it's overkill for nearly all my local riding and i think it'll be fun to switch between the two.
Steve_b77...i experimented with my forks throughout the whole ride and will continue to do so but i too felt i found a happy medium somewhere around the 115-120mm travel setting, 130mm felt odd. Some more fiddling to do i suspect.
Larry - I enjoyed Hidden Valley so much i did it twice and made my wife take several photos too!
Yeah they definitely suit a light fork at around 115 - 120mm, can never figure out why people put Pikes etc on them, they're not really the bike for that.
Mines an older frame, but in fairness I've had a couple of years off mountain biking, so while it is a (?) 2003 frame, and was only built in 2004, it's only had about 3 years use in that time. Note the canti-bosses on the seat stays.
Build is mostly XT drivetrain, Manitou Black forks (100/120mm travel), Easton bars & stem, Synchros post, Flite saddle. Formula B4 brakes, 180/140mm discs. I'm a bigger rider but still find the 19" bike maybe a touch too big, however I'm just a trail rider, so it does the job well. Regarding fork travel, the older frames are meant to run 100mm max, which I did used to run, but seeing as it is well out of warranty I've started running 120mm, and it rides better with the longer travel - mostly because the fork is working better on the longer setting, running at the same air pressure as i had in it when it was on 100mm.
I noticed you said you might get rid of the m4's in one of your first posts,
if you want to swap the m4's for some xt disc brakes then i could be interested!!
email in profile if your interested
cheers
steve
Steve...you have mail.
hello mate ive replied to you .... has it got through yet??
Hi all am new i have a 2010 cove hand job and i have 140mm Magura Thor 2010
you ? i be ok 140mm forks
and how do i post pic up
