Hi
Was hoping for a little help, I am looking to finally finish the build of my cotic soul ready for summer and wanted some advice on fork choice
I am pretty set on a set of travel adjust forks (i want the ability to run 140mm of travel on steep decent but running 110/120mm for single track or less steep descent)
I really like the new fox talas for the fact that i could set it for 20mm travel adjust instead of 30mm using spacers (ideally i’d like to run 140 – 120mm travel) other than that though the usual downside of fox forks comes in to consideration
I have also looked at X-fusion velvet RL2 DLA and Slant RL2 DLA. I think that if i am reading X fusions website correctly the slants can be internally reduced to 140 – 110mm travel and the velvets will come in 140 – 110mm as stock. I like the X-fusion for the fact that they can be adjusted to 650b if needed in the future (lets not open that can of worms now though). If I had the option i would prefer the slants over velvets as they are that much stiffer without much of a weight penalty but can someone just confirm that slants can be stepped down with the ladder and pin system like the non travel adjust version.
I also noticed that Merlin are selling two versions of both slants and velvets, one listed as 2013 the other without a year, what has been changed? i can’t find any info on new models since last year?
I have also had a look at marzocchi 44 micro switch TA, they are the correct length but i can’t find many rider reviews, they are also quite a bit more than a set of the x-fusions.
Lastly i have considered getting a set of dual position rockshox pikes and having the ASA machined down to 140mm max travel, i would like to know if this is possible? (i guess LoCo is the person to speak to) these would probably be closer to the fox in terms of pricing.
So i guess what i want is real wold reviews on any of the above, specifically the travel adjust systems for each brand?
Any thoughts on which are better (considering the huge variation in prices)?
and advice on the x fusions on merlins website?
Thank you
Josh
