I’m thinking about entering the world of 29ers and with me having a BFe and loving it, I reckon a Solaris would be a good place to start!
I’m a bit curious about 29er sizing, shoudl I just go with the same size as I would with a 26er?
I currently have a singlespeed Soul in a large and a medium BFe. The Soul with 120mm forks is a good size for general trail riding and the medium BFe with 140mm forks is good on the rougher stuff.
As I’m planning on using the Solaris for more general trail riding/XC type riding, would I be better off with a large frame?
Spec-wise I’ll probably be going for either 1×10 or 2×10 with Hope Hoops on Crest rims and a set of Fox Float 29 Evolution RL forks. Any better suggestions?
I’d go with whatever you’re comfortable with of your current frame sizes. I went up from a large Soda to and XL Solaris because the Soda was fractionally small. You might want to take 10mm off your stem though.
The build suggestions sound good. I’d look at Rebas personally. I’ve got both and rate the Rebas more.
I ride a large Solaris and came to it from a 20 inch Unit 2-9; the head tube is shorter than the Kona but the top tube length is very similar and it fits perfectly.
If you’re happy with your current cockpit, personally, I’d go for the frame with the nearest TT length, risers and seat post can compensate for any other differences.
Build wise, I’ve gone 1×9 (32×11/34) and in the Lakes last week it coped with everything bar Skiddaw but even the granny gears were pushing/carrying there.
Ride wise, its the greatest bike I’ve ever owned 🙂
I think Cy and Paul generally prefer a smaller bike – I went with a medium Soul and 90mm stem at their recommendation and it’s *just* big enough. Would be interested to ride a big one.
I’ve designed the Solaris to have 10mm longer top tubes than the equivalent 26″ bike to length the front centre and stop the weight distribution getting weird. That puts the medium Solaris between your BFe and Soul, and the large Solaris a bit longer. For trail riding in the mould of what you do on your Soul, get the large Solaris and put a 10mm shorter stem on it. That’s how it’s designed to be used.
I’m 5’10” and ride a mixture of fastish XC to wet rocky / rooty techie stuff. I initially rode a medium Simple with a 100mm 6Deg stem and 680mm low rise bars but then swapped out to the large frame with the same stem /bars as I wanted a slightly longer reach.
After speaking with Cy and considering the longer TT length on the Solaris I eventually opted for the ‘medium’ Solaris with a 90mm 0Deg stem and 580mm flat bars and so far it’s fine (Sorry Cy, I’ve stuck with the narrower bars, the trees are very close together up here!).
Don’t forget that your saddle position / seat post type will also play a small part in terms of your position on the bike. I initially used a zero layback post with a Brooks Ti Swift pushed all the way back (it has longer rails than my B17) but then put my B17 back on and I was surprised by just how much my ‘center’ changed on the bike. I ‘may’ pop on a slightly shorter stem but over all the ‘medium’ size is great.
@wisepranker – Solaris, Soul and BFe – that must put you in the premier league of Cotic owners, I merely have the BFe so clearly I’m in the Vauxhaul Conference ! I think we need to see a shot of the “stable” when you get the Solaris built up.
Just shy of 6″3″ 34″ inside leg and on a large at Cy’s suggestion. Mimics my old large Soul in terms of feel. Rebas,pro11s 90m stem and flat ti bars. 3×9 set up.Blue is lush in the flesh.
I took Cy’s advice and got the large, also influenced by the fact that I wanted something more ‘xc-trail’ to contrast with the 5spot I use for generally rougher/dumbass stuff.
Pretty happy with it in this capacity, but if I was using it for allround riding, I’d really struggle to decide which of the two sizes to go for. I love the way it carries speed though, and it does it with confidence and stability too.
I’m 6′ and have a Large Soul with a 90mm stem, so decided for a Large Solaris with a 70mm stem which i am very happy with.
I do have similar height friends though who find it too big and would probably suit a medium frame so it’s not just height as inside leg and arm length can play a part too.
I don’t have a Solaris (though I do have a Soul!) and one thing I’d add is that you can run a much shorter stem than is traditional to get a short enough ‘cockpit’ length for good cornering/descending/jumping and (now this is the really clever bit 😉 ) bend your arms when doing more pedally riding to put your torso in the optimum position.
Well after advice here from Cy and a conversation earlier with Paul from Cotic, I’ve got a large blue Solaris on it’s way 😀
Just got to figure out exactly what else I want build-wise!
I have a medium, I am 5.10 with 33″ legs, the medium with 70mm stem and 100mm rebas is perfect.
also have hope crest tubeless.
I have gone 1 x 10
mrp 28t bling ring
sram s1400 2 x 10 with the spder and rings removed and direct mounted the bling ring
bionicon v2 and gusset lil chap for the chain.
total weight with gravity dropper is 27lbs
