So this is where I’ve got to… Suggestions / alternative thoughts would be much appreciated…
Small kitchen in a Victorian terrace. Along the external wall we have the washing machine and dishwasher. These have sockets below the worktop and a fuse switch above the worktop.
Yesterday the power started tripping in the kitchen. By a process of elimination we worked out that if the fuse switch to the dishwasher was off then the problem was “solved”. So pulled out the washing machine and dishwasher and found the beginnings of some black spot mould on the external wall. Whipped off the socket covers and there’s the start of some corrosion inside the backboxes around the earth connection and sides of the box… This applies to both the sockets above and below the worktop.
My thoughts are that we’ve a lack of ventilation behind the washing machine and dishwasher and that we’re getting condensation on the cold external wall. This is causing the mould. I’m also thinking that we’re getting condensation in the backboxes which is causing the corrosion in there. So, solution 1 would appear to be to increase the ventilation behind the a Planes by adding some vents to the plinth, and worse case maybe even an airbrick to the back wall to allow direct ventilation (although I’d rather not do this just yet). However, does anyone think this would also address condensation in the back boxes or are these a bigger problem with being chased into a cold (and pos damp) crappy Victorian brick wall. In addition, a proper extractor fan rather than relying on the trickle vents and remembering to open the window is starting to seem like one of those daft omissions…
Any other thoughts / electricians who have come across corroded backboxes before and might know of anything else to consider? Plastic backboxes a possibility / sensible idea?
Thanks in advance!
