Viewing 40 posts - 41 through 80 (of 83 total)
  • Correct Chainlength For 1×9 Setup?
  • james
    “brought about by using the 3×9 method on a 2×9 set-up..”
    So?
    TJ is right no?
    If you were setting up 3×9, ignoring full suss extensions for the minute, youd go big big (not through r.mech) and overlap 1pair/2links(inner+outer) and chop chain, to make sure it shifts properly (sometimes youll get away with 1.5links or so overlap (3/4pair)
    If you were setting up (bash+)2×9 or 1×9, you still go biggest-biggest (not through r.mech) + 1pair/2links(inner+outer) overlap and then chop chain
    Cage length makes no difference to chain length
    No you shouldnt ride big-big for cross chain inefficienencies, but setup right you can ride big-big
    With 1×9 and/or short cage mech as it wont slap around the same as a long cage on a 1×9 setup you want the chain as short as possible but still want all your 1×9 gears
    In biggest-biggest in both 3×9 and 1×9 the mech will be almost flat/parallel with the chainstay. The 1pair of links/2links(inner+outer) makes up for this almost straight bit
    james
    This is my about 0.5 link length(~0.2 pair of links length) overlapped SS
    If it had a proper at least 1pair of links length/ 2 links length(inner+outer) overlap it would run properly with no tightness
    Being Singlespeed its in biggest-biggest, so mech is almost flat. The cage length would make no difference to what length the chain should be:
    (mech is too worn for geared use, and actually its a 2×1 .. but 22T ring is only for ’emergencies’)
    “+3 then add a powerlink”
    I see, then you only need overlap ‘+1’ and add a powerlink, as these 2 makes up your 1pair links length/2links length(inner+outer)
    james
    Hmm, I think what Ive written will read quite confusingly
    I get the impression there is some confusion through this thread (other than whether cage length makes a difference to minium chain length) as describing length of chain regarding length
    It seems 2 links means 4 chain pins worth of lenght to some, 1pair of links means 1 chainpins worth of length to others and 1 pair of links is 2 chainpins worth of length to some more ..
    GW
    No TJ and now You too are wrong.
    james
    Why?
    I dont get why cage length makes a difference to how short you can get your chain
    Somebody tell me what Im missing here, I could be missing something, but I dont see?
    tomtomthepipersson
    Just to clarify – On my 2×9 I run big to big then add 3 links and a power link. So I’m adding 4 individual links (2 inners and 2 outers). No idea if the standard plus2 Is 2 individual ones or 2 pairs or even how the power link comes into the equation. Mine works so that’s all I care about. 🙂
    GW
    Greeble already told you, it’s balls!
    You’ve had 5 months to work out why, I’ll give you another 5 and if you’re still struggling with it I “might” tell you why then.
    TandemJeremy
    I don’t know what reasoning there could be for big / big plus two links not being the right chain length – it works for any hardtail setup Teh plus two links gives enough slack for any mech in the gear combo tht has least chain slack
    Sheldon Brown says it is right
    The best technique for setting chain length is to thread the chain onto the large/large combination, without running it through the rear derailer. Mesh the two ends on to the large chainwheel so that one complete link (one inch, — one inner and one outer half-link) overlaps. In almost all cases, this will give the optimum length.
    and its how I always set up all my bikes regardless of mech length
    You want a chain as short as possible. Stops it dropping off / slapping around. Usual load of pish on here from folk. 🙂
    It works for 1×9
    IMG_2687 by TandemJeremy, on Flickr
    It works for 2×9
    IMG_2688 by TandemJeremy, on Flickr
    Note both mechs sitting at the right angle – not too tight – the 1×9 bike has the sweetest shift of any bike I have ridden.
    cynic-al
    Great reasoning here…”you’re wrong because you’re talking balls”
    Thanks for that giggle!
    yunki
    So?
    TJ is right no?
    surely though… mech size is irrelevant to my query..
    If you have 42 tooth largest chainring and 32 largest sprocket (a combination which you will never use)
    that will give a certain length for the chain which works very nicely across a 27 gear spread..
    I don’t see the logic in applying that same technique when measuring a chainlength of 32/32 where you will often be using big/big..
    the maths and physics and logic do not add up.. you’re using the same spread of gears in that chainring, but with a drastically shorter chain..
    teej, sorry mate, I didn’t open this thread as an attack on you, just a genuine enquiry..
    doesn’t having your rear mech over extended like that put extra strain on cables/pods/spring and allsorts..? it looks all kinds of uncomfortable
    Singlespeed_Shep
    i also have used the same method as TJ 2 chain links and its never failed on various bikes and mechs.
    GW
    How many single ring set- ups have you fitted TJ?
    – guessing not even in double figures, right?
    Your “made up” rule is NOT even always possible never mind giving optimum chain length.
    Yunki – very little to do with mech cage length.
    cqed
    plus one for TJ’s method.
    i use it on all 9 bikes that i own (various mtb/cx/road/single/double/triple permutations), and have never had a problem in several years.
    greeble
    oh look..
    there’s an in depth article on how long a chain should be
    http://www.pinkbike.com/news/Tech-Tuesday-Chain-Length-Basics-2012.html
    again so many people don’t have a clue and the who +2 links thing is utter rubbish
    you will complain the suspension isn’t working correctly so need a PUSH tune or a CCDB because the chain length is too short not taking into account the chain growth on a full sus bike and all you’ve done is got the chain length wrong
    TandemJeremy
    Greeble – I said you need to do this with the suspension in the position that the effective chainstay length is greatest with fullsussrers.
    GW – how could it be not possible? teh plus two links gives enough slack for any mech to go in.
    YOu need to provide some reasoning why this is not right as its the standard method
    james
    “complain the suspension isn’t working correctly so need a PUSH tune or a CCDB because the chain length is too short not taking into account the chain growth on a full sus”
    the biggest-biggest + inner+outer chain length overlap rule does work on a full suss, you just have to measure where the effective chainstay length is at its longest (wherever that point maybe within the suspension movement)
    Its what the shimano instructions that come with chains/casettes/mechs/shifters show on them
    ” rule is NOT even always possible never mind giving optimum chain length”
    When is it not possible?
    With a lower roller front chain device youd have to loop through that to ‘measure’ I guess?
    TandemJeremy
    no worries
    Its not over extended at all. Still slack inthe mech available – checkthe pink bike article the3 pic entitled chainjust right the mech angle is the same as I have
    GW
    TJ – are you going to answer my question? (seeing as I’m about to answer yours)
    firstly it seems you can’t count, in both your pics you seem to have added 4 links. (one chainlink comprising of just 2 plates)
    many suspension frames have too much chain growth for just 2 extra links or even 4.
    some set-ups (hardtail or full sus) will work smoothly with just 2 extra links added some will need 4 or more to opperate smoothly.
    even on a hardtail chainstay length variance can add up to an inch (or 2 links) variance between what length chain will run big to big and what won’t.
    size of the chainring and large sprocket also play a part in what works smoothly
    Which particular mech you are using will also play a part.
    even mech cage length and number of jocket wheel teeth play a tiny part
    as does mech hanger bolt location and chainstay design.
    Believe me when I tell you from a huge amount of experience it’s not as cut and dried as you seem to think.
    Ps. What would your beloved Sheldon say about running a worn out guide pulley on an ancient but top of the range rear mech?
    I’ll tell you, he’d probably say “it is not ideal” but he’d probably still run it being a bit of a pikey..
    same goes for your “standard”
    TandemJeremy
    One chainlink is an inner and an outer link
    I said yo have to measure this n full sussers at greatest cheffective chainstay length
    How – the chainstay length is fixed on a hardtail – this is taken into account with the amount of chain big – big
    Thats not a worn out jockey wheel – I have much used much worse 🙂
    Ihave set up a goodf few bikes over the years no idea how many but not dozens of 1/9s
    GW
    oh. FFS.
    you seriously think every hardtail has the same length chainstays?
    TandemJeremy
    No I do not – but it is irrelevant. Yes a longer chainstay needs a longer chain – but you get the greter length form the length you measure on the big to big. then you add two links to get enough slack to fit a mech.
    So a chain measured on a bike with a short chainstay will be too short on a bike with a long chainstay but the beauty of the big / big plus two links is that it takes account of this
    GW
    Ps. thanks for answering my question.
    You really don’t have anywhere near enough experience to be blindly chucking “standards” and “rules” about ass gospel.
    TandemJeremy
    If yo could explain a situation where this wouldn’t work………………
    GW
    Ok, You don’t “get” it, fair enough, why would you?
    join the chain as short as you can SS style on a vertical (or fixed) drop-out hardtail, depending on gear and chainstay length, that chain is going to be anything from too tight to use to too slack to stay on. there’s your variance!
    some riders (not you, granted) will want as short a chain as possible, the variance I’ve explained above can mean the difference between 2 links to that rider’s set-up.
    steve_b77
    GW – Member
    oh. FFS.
    I do hope thats a tongue in cheek comment, if a chainstay is 17″ long and you put the chain round the biggest front & biggest rear and add any number of links the chain will eb the correct length, the very same theory will apply to a chainstay that is 22″ long.
    GW – how do you set up yours?
    TandemJeremy
    Huh – and what does that have to do with anything? Yo still have not explained why big / big plus two links does not work in some cases.
    yes I want a chain a short as possible which is why I set it up as I do. one link shorter and it would not go into first without straining the mech
    MarkN
    I always had inner and outer plate, 3 roller/pins, equals one link. The half link chains tend to support that belief but I have never used one.
    Not checked the instructions in a while now but recall that Sram supported the big to big plus 2 concept.
    avdave2
    GW please explain how the chainstay length makes a difference on a hardtail when using the method suggested by TJ.
    That’s half a link
    PaulD
    Big-Big + 2 rivets is the official recommendation from Shimano and SRAM (goes off to check KMC).
    KMC helpfully suggest using the old chain as a pattern…hmmm.
    It also happens to work.
    Why all the fuss?
    Only point worth debating is where to put the rear suspension to get max chain length position….it is not always at one end.
    PaulD
    Dickyboy
    If you use the big to big plus two links system on a 1×9 set up, it MAY leave you with too short a chain. This is because on a 2×9 or 3×9 etc you should never actually use the biggest chain wheel to biggest sprocket, whereas on a 1×9 you obviously will do. For a 1×9 set up feed the chain over the biggest sprocket over the chainwheel & actually through the mech, then tension the chain so you still have an S shape in the chain as it runs through the jockeys. TJ’s photo above shows it as tight if not tighter than i would want to go & fitting a medium cage mech would leave you with a slightly more pronounced S, so mech length does make a slight difference too.
    TandemJeremy
    dicky boy – how can it leave you with two short a chain? the plus two links gives you enough slack to fit a mech, the big to big allows for the chainstay length. It cannot be two short and the shorter the chain the better so long as there is enough room for the mech
    My pics show the same angle as the pinkbike recommended right chain tension
    GW
    Tj/Avdave – re-read what I wrote.. take your times 😉
    TandemJeremy
    I have GW and it does not explain why big / big plus 2 links is wrong – especially as yo call half a link a whole link 🙂
    GW
    Far too fast 🙁
    that’s ok, you have 5 months to work it out too.
    TandemJeremy
    GW – I have reeally tried to see your point and cannot.
    james
    “many suspension frames have too much chain growth for just 2 extra links or even 4”
    Maybe from unsagged, but if you can work out where the effective chainstay length is at its longest and then hold it there then biggest-biggest + inner+outer links length overlap will work?
    “on a hardtail chainstay length variance “
    Eh?
    “One chainlink is an inner and an outer link”
    “big / big plus two links “
    I see, Ive been thinking your 2 links are one inner and one outer
    So youre setting up with 4 chain pins worth of length, when you could also use 2 chain pins of length (one of your chainlinks, rather than 2)
    “one link shorter and it would not go into first without straining the mech”
    I do with mine, they all seem alright
    “MAY leave you with too short a chain. This is because on a 2×9 or 3×9 etc you should never actually use the biggest chain wheel to biggest sprocket, whereas on a 1×9 you obviously will do”
    For 3×9 I wouldnt for crossed chain innefficiencies, but for (bash)2×9 I do go big-big. On short sharp up/down/up down type trails I leave the front mech alone and shift only with the rear
    1×9 I go that short too?
    How MAY it leave too short a chain?
    “so mech length does make a slight difference too”
    IF you set it up with excess chain like you describe, but if as short as will go with biggest-biggest + 2pins/rivets length, no?
    bedmaker
    Some ‘knowledgeable’ types making this much harder than it needs to be. TJ has got it right, it really ain’t that hard.
    1 link = 2 plates 😆 Bellend
    tomtomthepipersson
    On a 2×9? Nonsense.
    GiantJaunt
    Anyone know the correct chain length for a 1×10? 😀
    yunki
    thanks Dickyboy.. you have answered my question.. 🙂
The topic ‘Correct Chainlength For 1×9 Setup?’ is closed to new replies.
