My Carbon O’Hara (geddit?)…actually, it’s Jamie Oliver’s.
Fry chopped streaky bacon, turn down heat and add thinly sliced onions, garlic and courgettes* (added later as easily over cooked). Cook pasta (Penne works well for this). Meanwhile, mix an egg, cream and a good bit of Parmesan (depending on taste).
A minute before it should be finished, remove, drain and add to the pan. Flick the pan in a top tv chef stylee, and add the mixture. Stir for a few seconds, but be careful not to overcook the egg.
Tada.
(I’m sure mogrim’s tastes just as good).
* A nice way to slice the courgette is to quarter one lengthways, then run a knife along each slice to take away the pithy centre (which can taste a bit bitter when cooked). This should leave you with flattish slices of courgette which you then slice diagonally – giving you “penne” shaped slices. Looks and tastes lovely.
For veggies, I make this lots without the bacon for mrs deadly – needs quite a bit of salt but is perfectly passable.
Also, if you’re bored of tomato based sauces, then add a few dollops of mascarpone.
